I am using Ubuntu 16.04 LTS with ROS Kinetic distro.
I have a custom package called gps_msgs in my catkin_ws directory. I have other two packages that utilize the message by including it into source.
Now, one of the packages doesn't build without having "gps_msgs" inside the find_package() macro in CMakeLists.txt whereas the other one does.
The packages are nearly identical apart from the fact that one of them utilizes a 3rd party library. Here's the CMakeLists (package.xml files are almost identical, none of them include gps_msgs, I would like to know why that works too..):
Package #1:
project(can_control_node)
add_compile_options(-std=c++11)
  roscpp
  std_msgs
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
add_executable(can_control_node src/control_node.cpp)
target_link_libraries(can_control_node ${catkin_LIBRARIES})
Package #2:
project(gps)
  roscpp
  std_msgs
catkin_package(
  #CATKIN_DEPENDS std_msgs roscpp
  #INCLUDE_DIRS include
set(SOURCES
  src/an_packet_protocol.c
  src/spatial_packets.c
  src/rs232.c
include_directories(include/${PROJECT_NAME} ${catkin_INCLUDE_DIRS})
add_executable(gps_node
  src/gps_node.cpp
  ${SOURCES}
target_link_libraries(gps_node ${catkin_LIBRARIES})
Again, both packages have #include <gps_msgs/Navigation.h> in their source files. The gps_msgs/Navigation isn't mentioned AT ALL in either of the package.xml files. Package #1 builds, package #2 complains that gps_msgs/Navigation doesn't exist. All 3 packages are in separate directories in my catkin_ws, what's going on?
    $\begingroup$ i would suggest to try to ask that on ROS answers website as the community there is 100% dedicated to ROS $\endgroup$
    – N. Staub
    Dec 3, 2018 at 12:50
  • $\begingroup$ @N.Staub I have, I have a basic solution why but no real answer. $\endgroup$ Dec 4, 2018 at 9:51
I have managed to fix the issue.
I am still uncertain as to why it happens, catkin can be very unpredictable and what builds on one system doesn't builds on another one (experienced that yesterday).
This is an actual convention and has to be followed to achieve proper building sequence whenever you're trying to include a c:
  1. Add your message in package.xml in the <depend>your_msg</depend> tag.
  2. Add your message in CMakeLists.txt in the find_packages(catkin REQUIRED COMPONENTS roscpp your_msg) macro.
  3. Add include_directories(include ${catkin_INCLUDE_DIRS}) macro in CMakeLists.txt to get the message headers.
  4. Use add_dependencies(your_node ${catkin_EXPORTED_TARGETS}) macro in CMakeLists.txt to ensure that your messages are built first before building your target (most important step).
Hope this helps someone who is getting (message no found error during catkin_make).
Reference: catkin docs
    $\begingroup$ Glad you found an answer to your question! Please accept the answer with the check mark to the left of your answer body to mark is as resolved. $\endgroup$
    – Chuck
    Jan 3, 2019 at 19:29
    $\begingroup$ @Chuck, done brother $\endgroup$ Jan 5, 2019 at 11:58
