When using ROS:
Why use catkin build from catkin_tools instead of catkin_make?
I've been told catkin build is better but no one who tells me this can give me a reason why.
When using ROS:
The main difference is the isolated environment that you get with catkin build
. This makes the whole build configuration much more compartmentalized and robust to changes in the configuration (add/remove package, modify a cmake variable etc.)
Apart from that you also get much better and easily-readable colored cmdline output which makes the whole experience much more pleasant.
@SteveO's link also gives a nice summary of the changes between the tools.
Adding to catkin build
you also get many other useful subcommands with catkin
including catkin clean
for cleaning the build
, devel
and install
spaces, as well as catkin list
, catkin locate
, catkin profile
