I am very much new to robot building. I am building a robotic arm for a everyday use. Basically, it will be used to hold and position a yard tools while the tool is being used and will be controlled using remote control. I have already bought the brackets, but now I need to buy servo motors; Not sure which or what servo motors to buy. My yard tool weighs about 10 pound. So, I need to know the name and/or brand of servos I will most likely need. Any hints or clue will be highly appreciated. Thank you.
closed as primarily opinion-based by sempaiscuba, N. Staub, Greenonline, Ugo, Mark Booth Oct 11 at 16:46
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
  • Servos are usually rated for torque. At what distance from the servo do you want to hold the tool? For example, if you want to hold the tool 1 foot out from the axle of your servo, you would need a servo rated at 10 foot-pounds. That's a big servo, by the way - most hobbyist servos are rated in ounce-inches. – rcv Oct 9 at 20:49
  • I should have mentioned that I am also going to need 3 servo motors. The tool is going to be about one foot away from the servo motor. Well, I don't understand what you mean "BIG MOTORS." Then, what do they mean when they say servo motor rated for 10kg-cm? Isn't 10kg = 20lb? – ThN Oct 9 at 20:58
  • How high are you going to lift it? The greater the distance, the more powerful a servo you're going to need. – Tanner Swett Oct 9 at 22:23
  • 2
    I'm voting to close this question as off-topic because it's a shopping question – N. Staub Oct 10 at 6:29
  • @TannerSwett the highest it will go up off the ground is 6 to 8 inches off the ground. – ThN Oct 10 at 10:25
