I am trying to set up EGM (Externally Guided Motion from ABB) for Position Guidance using C#. But when the code reaches EGMSetupUC it will always give the error:
41824: Not possible to open the UdpUc device
Description
It was not possible to open the external device EGMsensor: that was specified in the RAPID instruction EGMSetupUC.
Consequences
The program execution is stopped immediately.
Actions
Check if
1) The device name is spelled correctly.
2) The device is connected.
3) The device is up and running.
The robot code is the following:
PROC mainEGM()
! Move to start position. Fine point is a demand
MoveJ p10,v300,fine,tMarkerAuto;
Test_EGM;
ENDPROC
PROC Test_EGM()
EGMReset egmID1;
egmSt1:=EGMGetState(egmID1);
TPWrite "EGM state: "\Num:=egmSt1;
EGMGetId egmID1;
IF egmSt1 <= EGM_STATE_CONNECTED THEN
! Set up the EGM data source: UdpUc server using device "EGMsensor:" and configruation "default"
EGMSetupUC ROB_1, egmID1, "default", "EGMsensor", \pose, \CommTimeout:=5;
ENDIF
Stop;
ENDPROC
In C#
private void EGMProcess(object caller, DoWorkEventArgs e)
UdpClient mUdpServer = new UdpClient(mPort);
IPEndPoint sender = new IPEndPoint(IPAddress.Any, mPort);
Console.WriteLine("Waiting for EGMRobot message...");
var protomessage = mUdpServer.Receive(ref sender);
Robot program won't go past EGMSetupUC and C# program won't get out of Receive, then I am deducing they can't connect with each other. Both are on the same network, in other projects we have confirmed that UDP protocol works fine, and we have used RRI and socket communication with this robot.
It is most likely a parameter configuration issue. Can someone help us with this??
