It's a little difficult to visualize rotations of a rotation sensor, so let's consider an accelerometer instead. You've got the same problem with an accelerometer: if the sensor isn't aligned with the chassis frame, you introduce a relative rotation $R_{struct}$.
Now, let's suppose some properties to go along with the accelerometer. We'll say it measures x- and y-axis accelerations, where +x is right/starboard and +y is forward. +z is up.
Let's also say that accelerometer has a y-axis bias of $1$ and an x-axis bias of 0. The chassis frame is currently accelerating at a rate of 1 $g$ forward.
If the accelerometer is well aligned to the chassis such that $R_{struct} = I$, then you get:
a_{meas} = \left[\begin{array}{ccc}
0 \\
g \\
\end{array}\right] + \left[\begin{array}{ccc}
0 \\
1 \\
\end{array}\right]
That is, for a well-aligned accelerometer, the x-axis output is $0$, from the fact that the chassis isn't accelerating along the x-axis, plus $0$, from the fact that the bias on the x-axis of that sensor is also zero.
The y-axis output is $g + 1$, from the chassis motion and the bias along the y-axis.
NOW, consider what happens if you rotate the sensor by +90 degrees about the z-axis. The sensor (+y) is now oriented along the chassis (-x) and the sensor (+x) is now oriented along the chassis (+y). Repeat the same measurement and now you get a reading of:
g \\
0 \\
0 \\
1 \\
\end{array}\right]
The chassis is accelerating at a rate of $g$ along its +y-axis, which the sensor is registering as a +x motion. However, the sensor is going to output a y-axis bias of $+1$ regardless of the orientation of the sensor.
That is, if there were no bias, your reading would be:
a_{unbiased} = R_{struct}a_{chassis} \\
The sensor bias is independent of the sensor orientation, so you add that to the unbiased reading:
a_{biased} = a_{meas} = a_{unbiased} + bias \\
\boxed{a_{meas} = R_{struct}a_{chassis} + bias} \\
Lastly, I believe if the bias were applied to all parameters, as you wrote:
\omega_{meas} = R_{struct}\left(\left(I-S\right)\omega_{true} + \beta + \nu\right) \\
That you could distribute the $R_{struct}$:
\omega_{meas} = R_{struct}\left(I-S\right)\omega_{true} + R_{struct}\beta + R_{struct}\nu \\
And then you could cleverly rotate your sensor to an angle of $\theta_{clever} = \mbox{atan2}\left(\beta_y,\beta_x\right)$ and have the entirety of the bias occur on one axis only and have the other axis be bias-free. That is, if the bias is based on sensor orientation, it would then become possible to affect bias or noise by altering the orientation of the sensor.
