I'm building a robot that uses the arduino uno microcontroller, and the tracks system is run by the tamiya 70168-Double-Gearbox-Kit.
Each Tamiya motor only uses 3V which is fine but it seems the stepper will help to control speed and direction of the motors. Does the Arduino Uno Microcontroller not allow you to control speed and direction?
Do I need a stepper to have control of the tamiya gearbox?
..... the gearbox has DC motors built in .... there appears to be no control mechanism that you could operate with a stepper motor $\endgroup$ – jsotola Sep 14 '18 at 14:59
