I am working on a language (computer language) for robotics to communicate with each other.
I am looking for naming standards that is unique and usable for robotics, for example when two robots are communicating with this language, they will use a word(standard) for an object like "door" that is understandable for both because they are using one unique naming standard.
As I searched the internet I couldn't find something helpful for naming objects, senses and actions may robots share with each other and they understand what are they meaning for.
Syntax of my language
SEND BY loc ON object = door
This language is a query language like SQL that programmer based on programming conditions writes communication queries to archive some data from destination robot or requesting some actions from it.
In the code above, loc
and door
are names that should be declared by a standard that both robots can understand them.
I'm asking you if you can suggest any naming standard for saving and sharing names on robots and if there is robotics communication standard to suggest especially scholars. thanks.
