We are using Ethernet as our current control bus and are considering switching to CAN. Our main computing unit is a PC under Ubuntu which needs to be fitted with a CAN port.
Anyone can recommend a PC to CAN hardware interface?
Any insight and experience feedback on using CAN on Ubuntu?
For low cost, but well designed and well supported in linux, I can recommend the USB2CAN from 8Devices.
If you will be booting windows occasionally to set up industrial drives or sensors, or doing real-time, stick with Peak or Kvasser.
If you will be adding a real-time kernel underneath Linux, check the driver list to confirm support for what you are buying.
CAN under linux with the socketCAN drivers works really nicely.
  • $\begingroup$ Really interesting! Your insight is invaluable, thanks! $\endgroup$
    – arennuit
    Jul 9, 2018 at 19:08
