I am working on an Autonomous underwater vehicle (AUV), and I do not know how to localize an acoustic source underwater
I know that I will use an array of hydrophones but how can actually get the position of the acoustic source
-are there any available commercial chips for acoustic signal processing? -are there any available books discussing that topic technically? -is there any known strategy for underwater acoustic source localization?
The simplest answer would be to use the phase difference to calculate the direction -- rotate your array until all sensors get the same phase, and you've found the direction to the source (or do some calculations based on the phase difference -- this does not require any mechanical movement).
For the distance -- use two separate arrays and triangulate the position from the two angles. If you don't have two arrays -- use the left and right half of the same array to calculate angles and go from there, the precision might suffer a bit, though.
  • $\begingroup$ I got the main Idea for what you are saying. Do you have any books or articles discussing these calculations with details ? $\endgroup$ Jun 25, 2018 at 23:11
  • $\begingroup$ @ShehabAldeen a quick google search for "hydrophone array" returned dtic.mil/dtic/tr/fulltext/u2/732042.pdf $\endgroup$
    – lenik
    Jun 26, 2018 at 1:35
