I want to publish via terminal a particular message format - sensor_msgs/Joy. However, every format I use seems to be wrong and I cannot understand how it is meant to be written on the terminal. On the internet all I can find is the generic structure and examples of similar messages but modifying my message based on that does not seem to produce any result. Say I want to publish that the object moves forward along a single axis while no motion in others. How do I achieve that with the proper syntax.
Also if you can let me know a place where I can find examples of the exact way I have to publish certain messages via terminal using rostopic pub.
