Our robot has a circular array of 12 sonar sensors that looks like this:
The sonar sensors themselves are pretty good. We use a low-pass filter to deal with noise, and the readings seem pretty accurate. However, when the robot comes across a flat surface like a wall, something weird happens. The sonars don't show readings that would indicate a wall, instead, it appears like a curved surface.
The plot below was made when the robot was facing a wall. See the curve in the blue lines, as compared to the straight red line. The red line was produced by using a camera to detect the wall, where the blue lines show filtered sonar readings.
We believe this error is due to crosstalk, where one sonar sensor's pulse bounces off the wall at an angle and is received by another sensor. This is a systematic error, so we can't really deal with it like we would with noise. Are there any solutions out there to correct for it?
