I bought two servos (HS-5685MH) for a pan-tilt-unit and somehow didn't see that they require 6.0 to 7.4 Volts which I don't have in my current setup. I have a 5V source that could provide the power, but I'm not sure what will happen to the motors if I use them with lower voltage.
Will they just be a bit slower or less powerful or could would I damage them with the lower voltage?
