I am applying Extended Kalman Filter for a mobile robot with IMU and odometry data. I am running simulation currently. However, I don't have suitable data for odo/IMU measurements to use. Where can I find those information?
1 Answer
Try this dataset, Localization and Mapping Dataset. It will be helpful for your problem.
$\begingroup$ Thanks but I need the data for IMU(which measures three angular velocities and three forces) and odometry which uses wheel data to calculate two velocities , Do you think you can help me with that? $\endgroup$– mahsaJun 9, 2018 at 6:38
$\begingroup$ No idea. I am working on this dataset. So I refer this. $\endgroup$ Jun 9, 2018 at 10:45
$\begingroup$ IMU is very unlikely to produce force output ... Typically IMU reading are 3 angular velocity from gyroscopes and 3 linear accelerations from accelerometers. $\endgroup$– N. StaubJun 15, 2018 at 10:08
1$\begingroup$ This is a bit of a link only answer. If the link dies then your answer will not be much use. $\endgroup$ Jul 11, 2018 at 7:28
