I have an old powered wheelchair motor from a Hoveround. I have removed the gearbox and I would like to attach a lawnmower blade directly to the shaft.
As you can see from the photo, it has 7 helical splines. Am I correct in assuming that I need a helical splined hub to mesh with it, which would either have a threaded shaft on the other side to hold the mower blade, or a method by which a threaded shaft can be connected?
If that's not the name of the part I need, what would it be? I've looked at many stores (McMaster, Servo City, etc) but can't seem to find something like this, which makes me think I am calling it the wrong thing.
FYI, the motor specs are:
- Brand: Shihlin
- Type: A9Y1X02872
- Part #: M19004442
- 24V DC
Thanks for any help.
