I'm having problems in finding reliable IMU's in ROS. So far, I have tried the UM7 and the myAHRS+ with no luck. The first one, keeps resetting its magnetic reference and the second one works well but the x axis is pointing to the north ( x-north, y-west, z-up convention ) instead to the east ( ROS convention x-east, y-north, z-up convention ).
Does anybody know one that works out of the box?
Best,
    $\begingroup$ What you require is a bit unclear, in particular the relation to ROS. Are you looking for hardware with ROS drivers ? Moreover, if the axis are not aligned to a convention you want to follow directly to the reading you can just apply a transformation matrix. Lastly the hardware you cite already contain kalmann filter so which output do you want of your IMU and for what purpose ? Keep in ming tht IMU are integrating accelerations to get positions so they are subject to drift ... $\endgroup$ – N. Staub May 22 '18 at 8:59
  • $\begingroup$ x axis is pointing to the north ... maybe that is the y axis $\endgroup$ – jsotola May 22 '18 at 17:26
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
