I found a good explanation on how to remove accelerometer bias (when on flat table only one axis should show values, the other two should be 0). I've calculated S and B factors (page 3):
Record $B_x^{0g}$, $B_y^{0g}$, $B_z^{0g}$, $S_{xx}$, $S_{yy}$, and $S_{zz}$ in EEPROM or flash memory and use these values in all subsequent calculations of acceleration to get the corrected outputs.
I don't know how to incorporate these into the final calculation of accelerations. I guess the bias should be substracted from my sensor reading. What about sensitivities (S)?
