A better approach would be to first ssh into the remote computer. In the remote terminal, run
export MASTER_URI = http://IP_address_master:Port_number
where IP_address_master
should be the IP address of the computer on which you want to run the master node. IP address could either be of your local machine or remote computer. Port_number
is the port of your master node (generally it is 11311
). On the same terminal, run
export ROS_IP = IP_address_remote
where IP_address_remote
is the IP of your remote computer.
In the terminal of your local machine (not the one where you are running ssh from), run the following commands:
export ROS_IP = IP_address_local
where, IP_address_master
and Port_number
is same as above but IP_address_local
should be the IP address of your local computer.
Now, you are ready to launch the file from your remote terminal. Your no longer require a separate launch file. In the ssh terminal, run the launch file kinect_left.launch
directly as:
roslaunch openni_launch_marvin kinect_left.launch
