I am trying to calculate jacobian with kdl (pykdl) and bullet physics (pybullet). With bullet physics I can only find Jacobian of whole robot, but I want to find Jacobian for a kinematic chain. So I wanted use kdl (pykdl) for the same.
I use pykdl_utils, which uses pykdl to calculate Jacobian for the given chain and to understand how kdl works, I am playing with a 7 DOF arm, after which I can try with the complex robot to get Jacobian for a given chain.
For, now I calculate Jacobian for the entire arm with origin point [0, 0, 0] of an end-effector in pybullet and using JntToJac(q_kdl, j_kdl) in pykdl.
I get the following results, which are approximately same,
jacobian from kdl
[[  3.93204983e-13   3.50279896e-01  -6.08147439e-13   6.97201042e-02
   -3.26970957e-13  -6.97201042e-02   0.00000000e+00]
 [ -4.41232355e-01  -2.08808746e-12  -4.41232355e-01  -2.14611370e-12
   -6.97201042e-02   1.96005964e-13   0.00000000e+00]
 [  0.00000000e+00   4.41232355e-01   1.44669450e-25  -4.41232355e-01
    5.57708303e-13   4.12323547e-02  -0.00000000e+00]]
jacobian from pybullet
((4.21021431342817e-08, 0.35027993596935714, 5.104112371956412e-08, 0.06972006581877463, 9.142687868923103e-09, -0.06972010078788882, 0.0), (-0.4412323331119607, 4.990932440307452e-08, -0.44123234585644516, 2.5382000887679235e-08, -0.06972010439253574, -4.292801227882336e-09, 0.0), (6.452008777913616e-23, 0.44123233311196214, -1.0899318209780877e-15, -0.4412323519515711, 1.2452388596192707e-09, 0.041232360892270135, 0.0))
But I don't get correct results when I try to calculate a Jacobian for a point other than origin, with j_kdl.changeRefPoint(pos_kdl) and through pybullet.
I use the following code, where I have copied few necessary functions from pykdl_utils, to post the code here, so that its installation can be avoided.
import pybullet as p
import math
import pybullet_data
import kdl_parser_py.urdf
import PyKDL as kdl
from urdf_parser_py.urdf import URDF
import numpy as np
def get_kdl_tree(robot_model, base_link, end_link):
    status, tree = kdl_parser_py.urdf.treeFromUrdfModel(robot_model, quiet=True)
    chain = tree.getChain(base_link, end_link)
    return tree, chain
def joint_list_to_kdl(q):
    if q is None:
        return None
    if type(q) == np.matrix and q.shape[1] == 0:
        q = q.T.tolist()[0]
    q_kdl = kdl.JntArray(len(q))
    for i, q_i in enumerate(q):
        q_kdl[i] = q_i
    return q_kdl
def kdl_to_mat(m):
    mat =  np.mat(np.zeros((m.rows(), m.columns())))
    for i in range(m.rows()):
        for j in range(m.columns()):
            mat[i,j] = m[i,j]
    return mat
def do_kdl_fk(q, chain, link_number):
    endeffec_frame = kdl.Frame()
    fk_kdl = kdl.ChainFkSolverPos_recursive(chain)
    kinematics_status = fk_kdl.JntToCart(joint_list_to_kdl(q),
                                               endeffec_frame,
                                               link_number)
    if kinematics_status >= 0:
        p = endeffec_frame.p
        M = endeffec_frame.M
        return np.mat([[M[0,0], M[0,1], M[0,2], p.x()],
                       [M[1,0], M[1,1], M[1,2], p.y()],
                       [M[2,0], M[2,1], M[2,2], p.z()],
                       [     0,      0,      0,     1]])
    else:
        return None
def forward(q, chain, base_link, end_link):
    base_trans = do_kdl_fk(q, chain, base_link)
    if base_trans is None:
        print "FK KDL failure on base transformation."
    end_trans = do_kdl_fk(q, chain, end_link)
    if end_trans is None:
        print "FK KDL failure on end transformation."
    return base_trans**-1 * end_trans
def get_kdl_jacobian(q, chain, base_link, end_link, pos=None):
    j_kdl = kdl.Jacobian(len(q))
    q_kdl = joint_list_to_kdl(q)
    jac_kdl = kdl.ChainJntToJacSolver(chain)
    jac_kdl.JntToJac(q_kdl, j_kdl)
    if pos is not None:
        ee_pos = forward(q, chain, base_link, end_link)[:3,3]
        pos_kdl = kdl.Vector(pos[0]-ee_pos[0], pos[1]-ee_pos[1],
                              pos[2]-ee_pos[2])
    J = kdl_to_mat(j_kdl)
    return J[:3, :], J[3:, :]
def transfomation_to_(frame_position, frame_orientation, point, inverse=False):
    rotation = kdl.Rotation.Quaternion(frame_orientation[0], frame_orientation[1], frame_orientation[2],
                                       frame_orientation[3])
    position = kdl.Vector(frame_position[0], frame_position[1], frame_position[2])
    frame = kdl.Frame(rotation, position)
    point = kdl.Vector(point[0], point[1], point[2])
    if inverse:
        point_on_frame = frame.Inverse() * point
    else:
        point_on_frame = frame * point
    return [point_on_frame[0], point_on_frame[1], point_on_frame[2]]
def getJointStates(robot):
    joint_states = p.getJointStates(robot, range(p.getNumJoints(robot)))
    joint_positions = [state[0] for state in joint_states]
    joint_velocities = [state[1] for state in joint_states]
    joint_torques = [state[3] for state in joint_states]
    return joint_positions, joint_velocities, joint_torques
if __name__ == '__main__':
    # clid = p.connect(p.SHARED_MEMORY)
    # p.connect(p.GUI)
    p.connect(p.DIRECT)
    p.setAdditionalSearchPath(pybullet_data.getDataPath())
    p.loadURDF("plane.urdf", [0, 0, 0], useFixedBase=True)
    kukaId = p.loadURDF("kuka_iiwa/model.urdf", [0, 0, 0], useFixedBase=True)
    p.resetBasePositionAndOrientation(kukaId, [0, 0, 0], [0, 0, 0, 1])
    kukaEndEffectorIndex = 6
    numJoints = p.getNumJoints(kukaId)
    if (numJoints != 7):
        exit()
    rp = [0, 0, 0, 0.5 * math.pi, 0, -math.pi * 0.5 * 0.66, 0]
    for i in range(numJoints):
        p.resetJointState(kukaId, i, rp[i])
    p.setGravity(0, 0, -10)
    t = 0.
    prevPose = [0, 0, 0]
    prevPose1 = [0, 0, 0]
    hasPrevPose = 0
    useNullSpace = 0
    count = 0
    useOrientation = 1
    useSimulation = 1
    useRealTimeSimulation = 0
    p.setRealTimeSimulation(useRealTimeSimulation)
    base_link, end_link = "lbr_iiwa_link_0", "lbr_iiwa_link_7"
    urdf_file = pybullet_data.getDataPath() + "/kuka_iiwa/model.urdf"
    model = URDF.from_xml_file(urdf_file)
    tree, chain = get_kdl_tree(model, base_link, end_link)
    q = getJointStates(kukaId)[0]
    # print q
    link_state = p.getLinkState(kukaId, 6, computeLinkVelocity=1,
                          computeForwardKinematics=1)
    link_frame_position = link_state[0]
    link_frame_orientation = link_state[1]
    zero_vec = [0] * len(q)
    pt = [0, 0, 0]
    pt1 = None
    pt2 = [0.02, 0, 0]
    pt3 = transfomation_to_(link_frame_position, link_frame_orientation, pt2)
    pt4 = transfomation_to_(link_frame_position, link_frame_orientation, pt2, inverse=True)
    # jac_t, _ = get_kdl_jacobian(q, chain, 0, 7, pt)
    jac_t, _ = get_kdl_jacobian(q, chain, 0, 7, pt1)
    # jac_t, _ = get_kdl_jacobian(q, chain, 0, 7, pt2)
    # jac_t, _ = get_kdl_jacobian(q, chain, 0, 7, pt3)
    # jac_t, _ = get_kdl_jacobian(q, chain, 0, 7, pt4)
    jac_t1, _ = p.calculateJacobian(kukaId, 6, pt, q, zero_vec, zero_vec)
    # jac_t1, _ = p.calculateJacobian(kukaId, 6, pt1, q, zero_vec, zero_vec)
    # jac_t1, _ = p.calculateJacobian(kukaId, 6, pt2, q, zero_vec, zero_vec)
    # jac_t1, _ = p.calculateJacobian(kukaId, 6, pt3, q, zero_vec, zero_vec)
    # jac_t1, _ = p.calculateJacobian(kukaId, 6, pt4, q, zero_vec, zero_vec)
    # only combination giving correct result: pt1 and pt
    print("jacobian from kdl")
    print (jac_t)
    print ("jacobian from pybullet")
    print (jac_t1)
Can someone please tell me, what is the mistake I am doing and how can I get correct results.
Thanks in advance.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
