I am running ROS Kinetic, on a Turtlebot3 Burger with a Raspberry Pi3.
The goal here is to remotely control the Turtlebot from another Raspberry Pi. The remote controller Pi sends movement information over a socket connection.
I have delay problems when publishing into /cmd_vel (60 seconds delay) and again delay of 60 seconds from when the Twist message is echoed in the topic /cmd_vel to when the Turtlebot starts moving. I cannot locate why this 2 x 60 seconds delay occurs. I think that I might be pushing the raspberry pi too much.
If I do the following steps: The Turtlebot3 is the ROS MASTER. 1. From remote SSH into the Raspberry Pi --> roslaunch turtlebot3_bringup turtlebot3_robot.launch 2. From remote SSH into the Raspberry Pi -- >roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
Everything works fine no delays.
When I do: The Turtlebot3 is the ROS MASTER. 1. From remote SSH into the Raspberry Pi --> roslaunch turtlebot3_bringup turtlebot3_robot.launch 2. From remote SSH into the Raspberry Pi -- >python post_office.py //python script posted below. 3. From remote SSH into the Raspberry Pi -- >rostopic echo /cmd_vel
The messages get into /cmd_vel with a 60 seconds delay. The Turtlebot3 starts moving after 120 seconds delay.
When I do: The REMOTE PC is the ROS MASTER. 1. roscore on remote pc 2. From remote SSH into the Raspberry Pi --> roslaunch turtlebot3_bringup turtlebot3_robot.launch 3. From remote SSH into the Raspberry Pi -- >python post_office.py //python script posted below. 4. Remote pc -- >rostopic echo /cmd_vel
The messages get into /cmd_vel with a 0 seconds delay. The Turtlebot3 starts moving after 35 seconds delay.
env | grep ROS gives the following when Turtlebot3 is ROS MASTER: ROS_ETC_DIR=/opt/ros/kinetic/etc/ros ROS_ROOT=/opt/ros/kinetic/share/ros ROS_MASTER_URI=http://192.168.1.39:11311 ROS_PACKAGE_PATH=/home/pi/catkin_ws/src:/opt/ros/kinetic/share ROSLISP_PACKAGE_DIRECTORIES=/home/pi/catkin_ws/devel/share/common-lisp ROS_HOSTNAME=192.168.1.39 ROS_DISTRO=kinetic
Here is the post_office.py running on the Turtlebot3.
import socket
import json
import rospy
from geometry_msgs.msg import Twist
import thread
import time
HOST = ''
PORT = 50007
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind((HOST, PORT))
s.listen(1)
conn, addr = s.accept()
print ('Connected by', addr)
twist = Twist()
lin = 0.0
ang = 0.0
pub = rospy.Publisher('/cmd_vel', Twist, queue_size=5) #queqe size can be adjusted maybe
def publish_cmd_vel():
    while not rospy.is_shutdown(): #checking the rospy.is_shutdown() flag and then doing work. You have to check is_shutdown() to check if your program should exit (e.g. if there is a Ctrl-C or otherwise).
        twist.linear.x = lin; twist.linear.y = 0; twist.linear.z = 0 #liniar has to be .x value to change
        twist.angular.x = 0; twist.angular.y = 0; twist.angular.z = ang #angular has to be .z value to change
        try:
            pub.publish(twist)
        except:
            print('unable to publish')
def recv_from_controller():
    while True:
        global lin, ang
        move_bytes = conn.recv(1024) #receive information as bytes
        move_info = json.loads(move_bytes) #decode into a dictionary
        lin = move_info['lin']
        ang = move_info['ang']
        print(type(lin), lin, type(ang), ang)
thread.start_new_thread( recv_from_controller, ())
rospy.init_node('post_office', anonymous = False)
while True:
    publish_cmd_vel()
Any ideas to why I get these delays?
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
