I'm making a consumer camera prototype and want to make the front look as clean as possible. Right now I use a completely transparent material and the camera and the IR Lights (with their red hue) are clearly visible. I'd like to move to a dark (as black as possible) material that makes the cover look flush and hides the sensors as much as possible.
What materials should I consider, if I want to minimize the impact on what the sensors perceive?
sensors
? ... you only mentioned an RGB camera ... what else is there? $\endgroup$ – jsotola Apr 17 '18 at 1:38
