I am trying to drive the differential drive kinematics of Turtlebot 2. However, I couldn't find the distance between 2 wheels on the datasheet. I'd appreciate if anyone could provide me this dimension.
Thanks.
  • $\begingroup$ Wow, that seems like a pretty critical dimension to be missing for a differential drive robot! $\endgroup$
    – Ben
    Dec 9, 2020 at 1:41
The specs are listed here:
https://www.active-robots.com/fileuploader/download/download/?d=0&file=custom%2Fupload%2FFile-1434995349.pdf
While they don't directly list the distance between wheels, they do list everything that you need for a kinematics model. I would especially focus on these two numbers:
  • Maximum translational velocity: 70 cm/s
  • Maximum rotational velocity: 180 deg/s
  • $\begingroup$ It appears that the link is broken. $\endgroup$
    – Ben
    Dec 9, 2020 at 1:40
23 cm from center to center. The wheel's width is 2.4 cm.
