My apologies but I've run out of ideas. I'm very new to python and stuck trying to execute the following code from this tutorial:
#!/usr/bin/env python
import rospy
from geometry_msgs.msg import Twist
import RPi.GPIO as GPIO
# Set the GPIO modes
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
_FREQUENCY = 20
def _clip(value, minimum, maximum):
# """Ensure value is between minimum and maximum."""
if value < minimum:
return minimum
elif value > maximum:
return maximum
return value
class Motor:
def __init__(self, forward_pin, backward_pin):
self._forward_pin = forward_pin
self._backward_pin = backward_pin
GPIO.setup(forward_pin, GPIO.OUT)
GPIO.setup(backward_pin, GPIO.OUT)
self._forward_pwm = GPIO.PWM(forward_pin, _FREQUENCY)
self._backward_pwm = GPIO.PWM(backward_pin, _FREQUENCY)
def move(self, speed_percent):
speed = _clip(abs(speed_percent), 0, 100)
# Positive speeds move wheels forward, negative speeds
# move wheels backward
if speed_percent < 0:
self._backward_pwm.start(speed)
self._forward_pwm.start(0)
else:
self._forward_pwm.start(speed)
self._backward_pwm.start(0)
class Driver:
def __init__(self):
rospy.init_node('driver')
self._last_received = rospy.get_time()
self._timeout = rospy.get_param('~timeout', 2)
self._rate = rospy.get_param('~rate', 10)
self._max_speed = rospy.get_param('~max_speed', 0.5)
self._wheel_base = rospy.get_param('~wheel_base', 0.091)
# Assign pins to motors. These may be distributed
# differently depending on how you've built your robot
self._left_motor = Motor(13, 15)
self._right_motor = Motor(36, 32)
self._left_speed_percent = 0
self._right_speed_percent = 0
# Setup subscriber for velocity twist message
rospy.Subscriber(
'cmd_vel', Twist, self.velocity_received_callback)
def velocity_received_callback(self, message):
# """Handle new velocity command message."""
# Extract linear and angular velocities from the message
linear = message.linear.x
angular = message.angular.z
# Calculate wheel speeds in m/s
left_speed = linear - angular*self._wheel_base/2
right_speed = linear + angular*self._wheel_base/2
# Ideally we'd now use the desired wheel speeds along
# with data from wheel speed sensors to come up with the
# power we need to apply to the wheels, but we don't have
# wheel speed sensors. Instead, we'll simply convert m/s
# into percent of maximum wheel speed, which gives us a
# duty cycle that we can apply to each motor.
self._left_speed_percent = (100 * left_speed/self._max_speed)
self._right_speed_percent = (100 * right_speed/self._max_speed)
def run(self):
# """The control loop of the driver."""
rate = rospy.Rate(self._rate)
# If we haven't received new commands for a while, we
# may have lost contact with the commander-- stop
# moving
delay = rospy.get_time() - self._last_received
if delay < self._timeout:
self._left_motor.move(self._left_speed_percent)
self._right_motor.move(self._right_speed_percent)
else:
self._left_motor.move(0)
self._right_motor.move(0)
rate.sleep()
def main():
driver = Driver()
# Run driver. This will block
driver.run()
if __name__ == '__main__':
main()
I get get the following error:
(classic)adeoduye@localhost:~/catkin_ws$ rosrun simple_robot_navigation driver_node_controller
File "/home/adeoduye/catkin_ws/src/simple_robot_navigation/src/driver_node_controller", line 117, in <module>
main()
NameError: name 'main' is not defined
BTW, it's ROS code which I have implemented in my custom catkin_ws/src/simple_robot_navigation package. I suspect it's a python issue but I very new at python and not sure how to fix it.
I would appreciate any help.
