I have both MATLAB and ROS installed on a SINGLE Linux machine. I am trying to publish data from MATLAB over a rostopic and echoing it in the terminal to view it. No matter, however, I play with URIs IPs /etc/hosts etc., I can't get to echo data in the linux terminal. I have tried setting MATLAB both as a master and as a node.
However, if I open multiple MATLAB Command Windows, I can echo the data inside it.
roswtf yields the following Found 1 warning(s). Warnings are things that may be just fine, but are sometimes at fault
WARNING Node [/vector_field] is not connected to anything
Found 1 error(s).
ERROR The following nodes should be connected but aren't:
/vector_field->/rostopic_1990_1521823771596 (/target_pose_hong_kong)
It seems like linux terminal and matlab commandline reside in different zones, and are just unable to communicate with each other.
  • $\begingroup$ I asked it on Matlab Answers forum few days back. But didn't get any answers. So posted here for larger community $\endgroup$ – Abdullah Nazir Mar 27 '18 at 17:58
  • $\begingroup$ I have dropped to configure matlab with ROS for now. Instead writing the data from matlab in a text file and reading/publishing it within ROS $\endgroup$ – Abdullah Nazir Mar 27 '18 at 18:01
  • $\begingroup$ is it possible that you are unable to connect because of differing data type? ... for example, text on one side and numeric on the other side $\endgroup$ – jsotola Mar 28 '18 at 21:09
  • $\begingroup$ have you read this? .... mathworks.com/help/robotics/ref/rosdevice.html $\endgroup$ – jsotola Mar 28 '18 at 21:15
  • $\begingroup$ I haven't. Thanks for sharing it. I was using rosinit directly without setting up any device. I will try this and see if this resolves my issue. $\endgroup$ – Abdullah Nazir Mar 29 '18 at 15:51
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
