I have a linear map, $J$, from one space to another. I can transform a covariance matrix, $P$, from one space to another by using:
$P' = JPJ^{T}$
However, in my situation I have an inverse covariance matrix, $P^{-1}$
The simplest way that I can think of transforming this is:
$P'^{-1} = (J(P^{-1})^{-1}J^{T})^{-1}$
which then using
$(A*B*C)^{-1} = C^{-1}B^{-1}A^{-1}$
should give
$P'^{-1} = (J^{T})^{-1}P^{-1}J^{-1}$
however, when I try this in MATLAB I do not find that these two representations are equal.
$(J(P^{-1})^{-1}J^{T})^{-1} = (J^{T})^{-1}P^{-1}J^{-1}$
It is actually correct.
I was comparing the two matrices using "==" which has no epsilon for comparing floating point numbers.
$(J(P^{−1})^{−1}J^{T})^{−1} = (J^{T})^{−1}P^{−1}J^{−1} = (JPJ^{T})^{-1}$
