I have a controller board for a motor, where I can read the motor current (to transform to torque), the position, the velocity and I can give a velocity command. There is not really a torque mode on this controller, that is I can only command velocity and read torque but I cannot give a torque reference.
How can use it to give a torque reference?, hence to comply with the standard robotic equation of the type
$\tau = m \ddot{q} + H(\dot{q},q) + G(q)$
That is that I get the $\tau$ value to send as reference, but in my case the controller board I have receives $\dot q$ and sends $\tau$. Is there a way to still use the standard equation for control ?
