I have built a Particles Filter simulator and I wanted to add the following functionalities.
- Limited Range Vision (Robot can see up to 50 meters)
- Limited Angle Vision (Robot can see within a certain angle w.r.t its current orientation. e.g. If the current orientation is 30 degree then it can see in the range from 0 to 60 degree.)
I have managed to add the Limited Range Vision functionality but unable to add Limited Angle Vision.
Method to Sense the landmarks distance within the range
public double[] sense(boolean addNoise) {
double[] z = new double[World.getLandmark().getLandmarks().size()];
for (int i = 0; i < z.length; i++) {
Point lm = World.getLandmark().getLandmarks().get(i);
double dx = x - lm.getX();
double dy = y - lm.getY();
double dist = Math.sqrt(Math.pow(dx, 2) + Math.pow(dy, 2));
if (addNoise) {
dist += Util.nextGaussian(0, sense_noise);
if (isBoundedVision()) {
// TODO Limited angle vision
// if robot can see within 60 degree angle w.r.t its orientation
if (dist <= laserRange) {
z[i] = dist;
} else {
z[i] = dist;
return z;
Method to calculate the probability of this particle
@Override
public double measurement_prob(double[] measurements) {
double prob = 1.0;
int c = 0;
double[] myMeasurements = sense(false);
for (int j = 0; j < measurements.length; j++) {
if (measurements[j] != 0) {
prob *= Util.gaussian(myMeasurements[j], sense_noise, measurements[j]);
c++;
if (c > 0) {
// increase the probability if this particle can see more landmarks
prob = Math.pow(prob, 1.0 / c);
} else {
prob = 0.0;
return prob;
Coordinates are relative to the robot and for distance calculation I am using the Euclidean Distance method and my Robot gets localized correctly.
