-1
I'm trying to design, using Matlab, a manipulator for transferring scrap metal but I have got stuck...
I want to model this manipulator in Matlab's Robotics System Toolbox. I need the D-H table, as the input parameters for that. I have performed some actions among them: designing the axes, composing the table. But I don't know, if I was right or wrong.
Here is a picture of the manipulator before axes design.
before my modification
Below is a picture of my design with axes and D-H table.
robot joint diagram
So, 4-DOF manipulator, 4 rotate joints, 1 prismatic. Grapple can rotate on 360 degrees, manipulator's column - 220 degrees.
What I want to know is
  1. Does the D-H table match the design?
  2. Does my design meet my needs?
I have a lot of other interesting questions. But firstly I need to finish deeds with forward kinematics.
After achieving the correct D-H table, I will try to derive A and T - matrices.
  • $\begingroup$ Welcome to Robotics manro, but I'm afraid that it is not clear what you are asking. We prefer practical, answerable questions based on actual problems that you face, so it's a good idea to include details of what you want to achieve, what you tried, what you saw & what you expected to see or don't understand. Please take a look at How to Ask & tour for more information on how stack exchange works and work through the Robotics question checklist to edit your question to make it clearer. $\endgroup$ – Mark Booth Jan 30 '18 at 14:16
  • $\begingroup$ Specifically, Yes, please add a picture, and the d-h parameters you currently have. If you add the information required to make the question on topic, we can re-open it for you (take it off hold) and then people will be able to answer your question. $\endgroup$ – Mark Booth Jan 30 '18 at 14:18
  • $\begingroup$ I see my problem with axis drawing ... you see a problem, but you do not say what it is. $\endgroup$ – jsotola Jan 30 '18 at 21:10
  • $\begingroup$ @jsotola I dont know, right I have drawn them or wrong... And D-H too. $\endgroup$ – manro Jan 30 '18 at 22:14
  • $\begingroup$ i do not understand what you are saying $\endgroup$ – jsotola Jan 31 '18 at 2:16
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
