I'm trying to implement a simple ROS node to perform Moving Least Squares filtering on a sensor_msgs/PointCloud2
topic.
I'm following this PCL tutorial, which uses the pcl/surface/mls.h file.
My code is at this GitHub page, but replicated below;
#include <ros/ros.h>
// PCL specific includes
#include <sensor_msgs/PointCloud2.h>
#include <pcl_conversions/pcl_conversions.h>
#include <pcl/point_cloud.h>
#include <pcl/point_types.h>
#include <pcl/io/pcd_io.h>
#include <pcl/kdtree/kdtree_flann.h>
#include <pcl/surface/mls.h>
* Simple class to allow appling a Moving Least Squares smoothing filter
class MovingLeastSquares {
private:
double _search_radius;
public:
MovingLeastSquares(double search_radius = 0.03)
: _search_radius(search_radius)
// Pass
ros::Subscriber sub;
ros::Publisher pub;
void cloudCallback (const sensor_msgs::PointCloud2ConstPtr& cloud_msg);
* Callback that performs the Point Cloud downsapling
void MovingLeastSquares::cloudCallback (const sensor_msgs::PointCloud2ConstPtr& cloud_msg)
// Container for original & filtered data
pcl::PCLPointCloud2 cloud;
// Convert to PCL data type
pcl_conversions::toPCL(*cloud_msg, cloud);
// Convert to dumbcloud
pcl::PointCloud<pcl::PointXYZ>::Ptr dumb_cloud (new pcl::PointCloud<pcl::PointXYZ> ());
//pcl::MsgFieldMap field_map;
//pcl::createMapping<pcl::PointXYZ>(cloud_msg->fields, field_map);
//pcl::fromPCLPointCloud2<pcl::PointXYZ>(cloud, *dumb_cloud);
// Create a KD-Tree
pcl::search::KdTree<pcl::PointXYZ>::Ptr tree (new pcl::search::KdTree<pcl::PointXYZ>);
// Output has the PointNormal type in order to store the normals calculated by MLS
pcl::PointCloud<pcl::PointNormal> mls_points;
// Init object (second point type is for the normals, even if unused)
pcl::MovingLeastSquares<pcl::PointXYZ, pcl::PointNormal> mls;
mls.setComputeNormals (true);
// Set parameters
mls.setInputCloud (dumb_cloud);
mls.setPolynomialFit (true);
mls.setSearchMethod (tree);
mls.setSearchRadius (_search_radius);
// Reconstruct
mls.process (mls_points);
// Convert from dumbcloud to cloud
pcl::PCLPointCloud2 cloud_filtered;
pcl::toPCLPointCloud2(mls_points, cloud_filtered);
// Convert to ROS data type
sensor_msgs::PointCloud2 output;
pcl_conversions::moveFromPCL(cloud_filtered, output);
// Publish the data
pub.publish (output);
* Main
int main (int argc, char** argv)
// Initialize ROS
ros::init (argc, argv, "pcl_mls");
ros::NodeHandle nh("~");
// Read optional leaf_size argument
double search_radius = 0.03;
if (nh.hasParam("search_radius"))
nh.getParam("search_radius", search_radius);
ROS_INFO("Using %0.4f as search radius", search_radius);
// Create our filter
MovingLeastSquares MovingLeastSquaresObj(search_radius);
const boost::function< void(const sensor_msgs::PointCloud2ConstPtr &)> boundCloudCallback = boost::bind(&MovingLeastSquares::cloudCallback, &MovingLeastSquaresObj, _1);
// Create a ROS subscriber for the input point cloud
MovingLeastSquaresObj.sub = nh.subscribe<sensor_msgs::PointCloud2> ("/input", 10, boundCloudCallback);
// Create a ROS publisher for the output point cloud
MovingLeastSquaresObj.pub = nh.advertise<sensor_msgs::PointCloud2> ("/output", 10);
// Spin
ros::spin ();
This compiles fine for me, but I don't get any points coming through the output topic. Can anyone tell me what I'm doing wrong? I suspect it is something to do with the conversions at line 46 or line 74.
Thank you!
