first question in this forum :D
so i started creating a 2 link robotic arm in SIMULINK and made a function that builds its trajectory (cubic spline) and used it as an input for my joint. so my input was position and output was the torque etc.
Now i would like my input to be torque,how do i go about it?
should i create a transfer function out of the dynamic equation OR can i use the trajectory in someway OR is there a simple way?
If you have an answer i would appreciate if you can send a detailed explanation on how you can do that in SIMULINK
Joint1
block, then you need to double click the joint, go to "Z Revolute Primitive" --> "Actuation" --> "Torque" and set it to "Provided by input," then set "Motion" to "Automatically computed." If you're asking how to generate a torque reference that you could pass to the torque input port for the joint, then the answer is however you want; open loop, PID, etc. $\endgroup$ – Chuck Jan 23 '18 at 16:14
