I run the following command to install GeographicLib datasets for mavros inside the catkin_ws directory (catkin workspace).
./src/mavros/mavros/scripts/install_geographiclib_datasets.sh
This script require root privileges!
but I get that message in return. what does it mean and how to get the above mavros dependency(GeographicLib datasets) installed successfully? Before this command, I followed the source installation process as mentioned here.
Do it with sudo:
sudo ./src/mavros/mavros/scripts/install_geographiclib_datasets.sh
