-2
I plan to do some scientific research, after modeling and path planning for the robot, The algorithm outputs the Joint control torque(or Joint variable), and then i want to input this result to the robot Control platform to check my algorithm, as far as I know, most robot can only provide point-to-point tracking instructions(NOT torque\joint variable input API),any robot can supports torque or joint variable as the robot input(when i input joint variable or torque, robot can move)?
How can I program a 6 DOF robot using torque rather than joint positions as input?
If you have any questions or concerns, don't hesitate to let me know.
  • $\begingroup$ It's not clear what you're asking. Do you just want a recommendation for a 6 dof robot that supports torque on a joint as input? $\endgroup$ Dec 25, 2017 at 18:26
  • $\begingroup$ @Eric Lavigne yes $\endgroup$
    – lumw
    Dec 25, 2017 at 21:03
This article explains how to implement joint-torque control on top of position-controlled robots.
Implementing Torque Control with High-Ratio Gear Boxes and without Joint-Torque Sensors https://hal.archives-ouvertes.fr/hal-01136936/document
Copied from another StackExchange question:
https://robotics.stackexchange.com/a/7531/18316
  • $\begingroup$ this one can supports torque or joint variable as robot input? $\endgroup$
    – lumw
    Dec 25, 2017 at 21:05
