Can anyone name a good source for a general approach (cookbook-like) for the inverse kinematics regarding a 5-DOF?
The paper by De Xu et al. is aiming for a general approach, but it doesn't work for my code. Maybe you could check that one as well?!
I am new to MATLAB, the code is no masterpiece:
Parameter used:
a=[0 82 93 55 95 0];
d=[47 0 0 0 0 10];
alpha=[90 0 0 0 0 0];
theta=[15 30 40 -90 -15 0];
Result for Theta 1-5:
- 5,080
- 38,029
- 75,947
- -90,247
20,719
EDIT: The results 1-5 mentioned above are the one the code gave me. But those are wrong, because:
Position of TCP (taken form the Forward Kinematics):
px= -5.7853
py= 5.7606
pz= 25.908
Position of TCP (using the calculating values for Theta 1-5):
px= 47.0
py= -151.0
pz= 43.9430
All values in degrees. I am using 5 servos by Dynamixel ax-12a.
d=[47 0 0 0 0 10];
theta=[15 30 -90 0 45 0];
rad=57.295779513082;
T01=[cos(theta(1)),-sin(theta(1))*cos(alpha(1)),sin(theta(1))*sin(alpha(1)),a(1)*cos(theta(1));
sin(theta(1)),cos(theta(1))*cos(alpha(1)),-cos(theta(1))*sin(alpha(1)),a(1)*sin(theta(1));
0,sin(alpha(1)),cos(alpha(1)),d(1);
0,0,0,1];
T12=[cos(theta(2)),-sin(theta(2))*cos(alpha(2)),sin(theta(2))*sin(alpha(2)),a(2)*cos(theta(2));
sin(theta(2)),cos(theta(2))*cos(alpha(2)),-cos(theta(2))*sin(alpha(2)),a(2)*sin(theta(2));
0,sin(alpha(2)),cos(alpha(2)),d(2);
0,0,0,1];
T23=[cos(theta(3)),-sin(theta(3))*cos(alpha(3)),sin(theta(3))*sin(alpha(3)),a(3)*cos(theta(3));
sin(theta(3)),cos(theta(3))*cos(alpha(3)),-cos(theta(3))*sin(alpha(3)),a(3)*sin(theta(3));
0,sin(alpha(3)),cos(alpha(3)),d(3);
0,0,0,1];
T34=[cos(theta(4)),-sin(theta(4))*cos(alpha(4)),sin(theta(4))*sin(alpha(4)),a(4)*cos(theta(4));
sin(theta(4)),cos(theta(4))*cos(alpha(4)),-cos(theta(4))*sin(alpha(4)),a(4)*sin(theta(4));
0,sin(alpha(4)),cos(alpha(4)),d(4);
0,0,0,1];
T45=[cos(theta(5)),-sin(theta(5))*cos(alpha(5)),sin(theta(5))*sin(alpha(5)),a(5)*cos(theta(5));
sin(theta(5)),cos(theta(5))*cos(alpha(5)),-cos(theta(5))*sin(alpha(5)),a(5)*sin(theta(5));
0,sin(alpha(5)),cos(alpha(5)),d(5);
0,0,0,1];
T56=[cos(theta(6)),-sin(theta(6))*cos(alpha(6)),sin(theta(6))*sin(alpha(6)),a(6)*cos(theta(6));
sin(theta(6)),cos(theta(6))*cos(alpha(6)),-cos(theta(6))*sin(alpha(6)),a(6)*sin(theta(6));
0,sin(alpha(6)),cos(alpha(6)),d(6);
0,0,0,1];
T06=T01*T12*T23*T34*T45*T56; %transformation matrix
inv_T01=inv(T01);
inv_T12=inv(T12);
inv_T23=inv(T23);
inv_T56=inv(T56);
T05=T06*inv_T56;
%needed for theta4 and theta5
Inverse=inv_T23*inv_T12*inv_T01*T06*inv_T56;
T_4_5=T34*T45;
N=T06(1:3,1);
nx=N(1,1);
ny=N(2,1);
nz=N(3,1);
O=T06(1:3,2);
ox=O(1,1);
oy=O(2,1);
oz=O(3,1);
A=T06(1:3,3);
ax=A(1,1);
ay=A(2,1);
az=A(3,1);
P=T06(1:3,4); %comapre to (17) in paper
px=P(1,1);
py=P(2,1);
pz=P(3,1);
px_2=T05(1,4);
py_2=T05(2,4);
%theta1
help1=px_2; %not sure
help2=py_2; %not sure
help3=(px_2*(-1)); %not sure
help4=(py_2*(-1)); %not sure
theta11=atan2(help2,help1);
theta12=atan2(help4,help3); %using this
theta1=atan2(py,px); %most common way
%Theta2
B1=(az*d(6)-pz+d(1));
B2=(sqrt((-ax*d(6)+px).^2+(-ay*d(6)+py).^2))-a(1); %taking only positive value, alternative: [1 -1]*sqrt
B3=((B1.^2+B2.^2+a(2).^2-d(4).^2));
%auxiliary angle
beta=(atan2(B2,B1));
root=((a(2)*a(2))*sqrt(B1.^2+B2.^2));
theta21=(asin(B3/root)-beta);%works best
theta22=pi-theta21;
%theta3
theta3=atan2(B1-a(2)*sin(theta21),B2-a(2)*cos(theta21))-theta21; %using theta21 is close to determined angle BUT still far away from acceptable
%theta4
%auxiliary
OX=(ox*cos(theta1).*sin(theta21+theta3));
OY=(oy*sin(theta1).*sin(theta21+theta3));
OZ=(oz*cos(theta21+theta3));
theta4=atan2(-OX-OY-OZ,ox.*sin(theta1)*oy.*cos(theta1));%as in the case
%theta5
%auxiliary
NX=(nx*cos(theta1).*cos(theta21+theta3));
NY=(ny*sin(theta1).*cos(theta21+theta3));
NZ=(nz*sin(theta21+theta3));
AX=(ax*cos(theta1).*cos(theta21+theta3));
AY=(ay*sin(theta1).*sin(theta21+theta3));
theta5=atan2(NX+NY-NZ,-AX+AY-az*sin(theta21+theta3));%as in the case
theta12*rad
theta21*rad
theta3*rad
theta4*rad
theta5*rad
enter code here
