I have been trying to build my ROS workspace using catkin_make, where i have cloned a repo/PACKAGE. I tried many of the things mentioned in previous answers to questions similar to my issue but without any progress. I tried building another package and it worked well. I am new to ROS and Linux, and this issue has been impeding me for a 3 days now.
Many thanks in advance!
abouseif@abouseif-ThinkCentre-M92p:~/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws$ catkin_make
Base path: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws
Source space: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src
Build space: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/build
Devel space: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/devel
Install space: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/install
#### Running command: "cmake /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/install -G Unix Makefiles" in "/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/kinetic
-- This workspace overlays: /opt/ros/kinetic
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.8
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 3 packages in topological order:
-- ~~ - gazebo_grasp_plugin
-- ~~ - kuka_arm
-- ~~ - kr210_claw_moveit
-- +++ processing catkin package: 'gazebo_grasp_plugin'
-- ==> add_subdirectory(RoboND-Kinematics-Project/gazebo_grasp_plugin)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- thread
-- signals
-- system
-- filesystem
-- program_options
-- regex
-- iostreams
-- date_time
-- chrono
-- atomic
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so
-- Looking for OGRE...
-- OGRE_PREFIX_WATCH changed.
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for module 'OGRE'
-- Found OGRE, version 1.9.0
-- Found Ogre Ghadamon (1.9.0)
-- Found OGRE: optimized;/usr/lib/x86_64-linux-gnu/libOgreMain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreMain.so
-- Looking for OGRE_Paging...
-- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
-- Looking for OGRE_Terrain...
-- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
-- Looking for OGRE_Property...
-- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
-- Looking for OGRE_RTShaderSystem...
-- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
-- Looking for OGRE_Volume...
-- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
-- Looking for OGRE_Overlay...
-- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:166 (message):
catkin_package() DEPENDS on 'gazebo' but neither 'gazebo_INCLUDE_DIRS' nor
'gazebo_LIBRARIES' is defined.
/opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
RoboND-Kinematics-Project/gazebo_grasp_plugin/CMakeLists.txt:32 (catkin_package)
-- +++ processing catkin package: 'kuka_arm'
-- ==> add_subdirectory(RoboND-Kinematics-Project/kuka_arm)
-- kuka_arm: 0 messages, 1 services
-- +++ processing catkin package: 'kr210_claw_moveit'
-- ==> add_subdirectory(RoboND-Kinematics-Project/kr210_claw_moveit)
-- Configuring done
WARNING: Target "trajectory_sampler" requests linking to directory "/opt/ros/kinetic/lib/roslib". Targets may link only to libraries. CMake is dropping the item.
-- Generating done
-- Build files have been written to: /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/build
#### Running command: "make -j4 -l4" in "/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/build"
Scanning dependencies of target trajectory_msgs_generate_messages_lisp
Scanning dependencies of target actionlib_msgs_generate_messages_lisp
Scanning dependencies of target trajectory_msgs_generate_messages_nodejs
Scanning dependencies of target trajectory_msgs_generate_messages_py
[ 0%] Built target trajectory_msgs_generate_messages_nodejs
[ 0%] Built target actionlib_msgs_generate_messages_lisp
[ 0%] Built target trajectory_msgs_generate_messages_lisp
[ 0%] Built target trajectory_msgs_generate_messages_py
Scanning dependencies of target trajectory_msgs_generate_messages_eus
Scanning dependencies of target gazebo_msgs_generate_messages_py
Scanning dependencies of target dynamic_reconfigure_gencfg
Scanning dependencies of target dynamic_reconfigure_generate_messages_py
[ 0%] Built target trajectory_msgs_generate_messages_eus
[ 0%] Built target dynamic_reconfigure_generate_messages_py
[ 0%] Built target gazebo_msgs_generate_messages_py
[ 0%] Built target dynamic_reconfigure_gencfg
Scanning dependencies of target dynamic_reconfigure_generate_messages_cpp
Scanning dependencies of target dynamic_reconfigure_generate_messages_eus
Scanning dependencies of target dynamic_reconfigure_generate_messages_lisp
Scanning dependencies of target tf2_msgs_generate_messages_nodejs
[ 0%] Built target dynamic_reconfigure_generate_messages_cpp
[ 0%] Built target dynamic_reconfigure_generate_messages_eus
[ 0%] Built target dynamic_reconfigure_generate_messages_lisp
[ 0%] Built target tf2_msgs_generate_messages_nodejs
Scanning dependencies of target tf2_msgs_generate_messages_lisp
Scanning dependencies of target tf2_msgs_generate_messages_eus
Scanning dependencies of target tf2_msgs_generate_messages_cpp
Scanning dependencies of target dynamic_reconfigure_generate_messages_nodejs
[ 0%] Built target tf2_msgs_generate_messages_lisp
[ 0%] Built target tf2_msgs_generate_messages_eus
[ 0%] Built target tf2_msgs_generate_messages_cpp
[ 0%] Built target dynamic_reconfigure_generate_messages_nodejs
Scanning dependencies of target std_srvs_generate_messages_cpp
Scanning dependencies of target _catkin_empty_exported_target
Scanning dependencies of target roscpp_generate_messages_nodejs
Scanning dependencies of target tf_generate_messages_eus
[ 0%] Built target std_srvs_generate_messages_cpp
[ 0%] Built target _catkin_empty_exported_target
[ 0%] Built target roscpp_generate_messages_nodejs
[ 0%] Built target tf_generate_messages_eus
Scanning dependencies of target geometry_msgs_generate_messages_nodejs
Scanning dependencies of target std_msgs_generate_messages_lisp
Scanning dependencies of target roscpp_generate_messages_lisp
[ 0%] Built target geometry_msgs_generate_messages_nodejs
Scanning dependencies of target geometry_msgs_generate_messages_lisp
[ 0%] Built target std_msgs_generate_messages_lisp
[ 0%] Built target roscpp_generate_messages_lisp
Scanning dependencies of target std_srvs_generate_messages_lisp
Scanning dependencies of target geometry_msgs_generate_messages_eus
[ 0%] Built target geometry_msgs_generate_messages_lisp
Scanning dependencies of target roscpp_generate_messages_cpp
[ 0%] Built target std_srvs_generate_messages_lisp
[ 0%] Built target geometry_msgs_generate_messages_eus
Scanning dependencies of target actionlib_msgs_generate_messages_py
Scanning dependencies of target std_msgs_generate_messages_py
[ 0%] Built target roscpp_generate_messages_cpp
Scanning dependencies of target gazebo_msgs_generate_messages_nodejs
[ 0%] Built target actionlib_msgs_generate_messages_py
[ 0%] Built target std_msgs_generate_messages_py
Scanning dependencies of target gazebo_msgs_generate_messages_cpp
[ 0%] Built target gazebo_msgs_generate_messages_nodejs
Scanning dependencies of target std_msgs_generate_messages_nodejs
Scanning dependencies of target geometry_msgs_generate_messages_py
[ 0%] Built target gazebo_msgs_generate_messages_cpp
Scanning dependencies of target trajectory_msgs_generate_messages_cpp
[ 0%] Built target std_msgs_generate_messages_nodejs
[ 0%] Built target geometry_msgs_generate_messages_py
Scanning dependencies of target geometry_msgs_generate_messages_cpp
[ 0%] Built target trajectory_msgs_generate_messages_cpp
Scanning dependencies of target sensor_msgs_generate_messages_nodejs
Scanning dependencies of target rosgraph_msgs_generate_messages_cpp
[ 0%] Built target geometry_msgs_generate_messages_cpp
Scanning dependencies of target rosgraph_msgs_generate_messages_nodejs
[ 0%] Built target sensor_msgs_generate_messages_nodejs
[ 0%] Built target rosgraph_msgs_generate_messages_cpp
[ 0%] Built target rosgraph_msgs_generate_messages_nodejs
Scanning dependencies of target roscpp_generate_messages_eus
Scanning dependencies of target std_msgs_generate_messages_eus
Scanning dependencies of target std_srvs_generate_messages_py
Scanning dependencies of target gazebo_msgs_generate_messages_eus
[ 0%] Built target roscpp_generate_messages_eus
[ 0%] Built target std_msgs_generate_messages_eus
[ 0%] Built target std_srvs_generate_messages_py
[ 0%] Built target gazebo_msgs_generate_messages_eus
Scanning dependencies of target rosgraph_msgs_generate_messages_eus
Scanning dependencies of target std_srvs_generate_messages_eus
Scanning dependencies of target tf_generate_messages_cpp
Scanning dependencies of target actionlib_generate_messages_eus
[ 0%] Built target rosgraph_msgs_generate_messages_eus
[ 0%] Built target tf_generate_messages_cpp
[ 0%] Built target actionlib_generate_messages_eus
[ 0%] Built target std_srvs_generate_messages_eus
Scanning dependencies of target rosgraph_msgs_generate_messages_lisp
Scanning dependencies of target std_srvs_generate_messages_nodejs
Scanning dependencies of target gazebo_ros_gencfg
Scanning dependencies of target rosgraph_msgs_generate_messages_py
[ 0%] Built target rosgraph_msgs_generate_messages_lisp
[ 0%] Built target gazebo_ros_gencfg
[ 0%] Built target rosgraph_msgs_generate_messages_py
[ 0%] Built target std_srvs_generate_messages_nodejs
Scanning dependencies of target tf_generate_messages_lisp
Scanning dependencies of target roscpp_generate_messages_py
Scanning dependencies of target tf_generate_messages_py
Scanning dependencies of target tf_generate_messages_nodejs
[ 0%] Built target tf_generate_messages_lisp
[ 0%] Built target roscpp_generate_messages_py
[ 0%] Built target tf_generate_messages_py
[ 0%] Built target tf_generate_messages_nodejs
Scanning dependencies of target sensor_msgs_generate_messages_cpp
Scanning dependencies of target gazebo_msgs_generate_messages_lisp
Scanning dependencies of target sensor_msgs_generate_messages_lisp
Scanning dependencies of target sensor_msgs_generate_messages_py
[ 0%] Built target sensor_msgs_generate_messages_cpp
[ 0%] Built target gazebo_msgs_generate_messages_lisp
[ 0%] Built target sensor_msgs_generate_messages_lisp
[ 0%] Built target sensor_msgs_generate_messages_py
Scanning dependencies of target tf2_msgs_generate_messages_py
Scanning dependencies of target actionlib_generate_messages_cpp
Scanning dependencies of target std_msgs_generate_messages_cpp
Scanning dependencies of target actionlib_msgs_generate_messages_nodejs
[ 0%] Built target actionlib_generate_messages_cpp
[ 0%] Built target tf2_msgs_generate_messages_py
[ 0%] Built target actionlib_msgs_generate_messages_nodejs
[ 0%] Built target std_msgs_generate_messages_cpp
Scanning dependencies of target actionlib_msgs_generate_messages_cpp
Scanning dependencies of target sensor_msgs_generate_messages_eus
Scanning dependencies of target actionlib_generate_messages_py
Scanning dependencies of target actionlib_generate_messages_nodejs
[ 0%] Built target sensor_msgs_generate_messages_eus
[ 0%] Built target actionlib_msgs_generate_messages_cpp
[ 0%] Built target actionlib_generate_messages_py
[ 0%] Built target actionlib_generate_messages_nodejs
Scanning dependencies of target actionlib_generate_messages_lisp
Scanning dependencies of target actionlib_msgs_generate_messages_eus
Scanning dependencies of target graph_msgs_generate_messages_lisp
Scanning dependencies of target octomap_msgs_generate_messages_cpp
[ 0%] Built target actionlib_generate_messages_lisp
[ 0%] Built target actionlib_msgs_generate_messages_eus
[ 0%] Built target octomap_msgs_generate_messages_cpp
[ 0%] Built target graph_msgs_generate_messages_lisp
Scanning dependencies of target object_recognition_msgs_generate_messages_nodejs
Scanning dependencies of target object_recognition_msgs_generate_messages_lisp
Scanning dependencies of target octomap_msgs_generate_messages_py
Scanning dependencies of target moveit_msgs_generate_messages_lisp
[ 0%] Built target object_recognition_msgs_generate_messages_nodejs
[ 0%] Built target object_recognition_msgs_generate_messages_lisp
[ 0%] Built target octomap_msgs_generate_messages_py
[ 0%] Built target moveit_msgs_generate_messages_lisp
Scanning dependencies of target moveit_msgs_generate_messages_eus
Scanning dependencies of target object_recognition_msgs_generate_messages_eus
Scanning dependencies of target visualization_msgs_generate_messages_lisp
Scanning dependencies of target moveit_msgs_generate_messages_cpp
[ 0%] Built target object_recognition_msgs_generate_messages_eus
[ 0%] Built target visualization_msgs_generate_messages_lisp
[ 0%] Built target moveit_msgs_generate_messages_eus
Scanning dependencies of target object_recognition_msgs_generate_messages_py
[ 0%] Built target moveit_msgs_generate_messages_cpp
Scanning dependencies of target graph_msgs_generate_messages_cpp
Scanning dependencies of target _kuka_arm_generate_messages_check_deps_CalculateIK
[ 0%] Built target object_recognition_msgs_generate_messages_py
Scanning dependencies of target shape_msgs_generate_messages_cpp
[ 0%] Built target graph_msgs_generate_messages_cpp
Scanning dependencies of target graph_msgs_generate_messages_py
[ 0%] Built target shape_msgs_generate_messages_cpp
Scanning dependencies of target moveit_msgs_generate_messages_nodejs
Scanning dependencies of target shape_msgs_generate_messages_py
[ 0%] Built target moveit_msgs_generate_messages_nodejs
[ 0%] Built target graph_msgs_generate_messages_py
[ 0%] Built target shape_msgs_generate_messages_py
Scanning dependencies of target visualization_msgs_generate_messages_cpp
Scanning dependencies of target visualization_msgs_generate_messages_py
[ 0%] Built target _kuka_arm_generate_messages_check_deps_CalculateIK
[ 0%] Built target visualization_msgs_generate_messages_cpp
Scanning dependencies of target visualization_msgs_generate_messages_eus
[ 0%] Built target visualization_msgs_generate_messages_py
Scanning dependencies of target object_recognition_msgs_generate_messages_cpp
Scanning dependencies of target visualization_msgs_generate_messages_nodejs
[ 0%] Built target visualization_msgs_generate_messages_eus
Scanning dependencies of target octomap_msgs_generate_messages_eus
[ 0%] Built target object_recognition_msgs_generate_messages_cpp
[ 0%] Built target visualization_msgs_generate_messages_nodejs
[ 0%] Built target octomap_msgs_generate_messages_eus
Scanning dependencies of target moveit_msgs_generate_messages_py
Scanning dependencies of target octomap_msgs_generate_messages_lisp
Scanning dependencies of target graph_msgs_generate_messages_eus
Scanning dependencies of target shape_msgs_generate_messages_lisp
[ 0%] Built target moveit_msgs_generate_messages_py
[ 0%] Built target octomap_msgs_generate_messages_lisp
[ 0%] Built target graph_msgs_generate_messages_eus
Scanning dependencies of target kuka_arm_generate_messages_py
[ 0%] Built target shape_msgs_generate_messages_lisp
Scanning dependencies of target shape_msgs_generate_messages_eus
[ 8%] Generating Python code from SRV kuka_arm/CalculateIK
Scanning dependencies of target octomap_msgs_generate_messages_nodejs
Scanning dependencies of target kuka_arm_generate_messages_eus
[ 8%] Built target shape_msgs_generate_messages_eus
[ 16%] Built target octomap_msgs_generate_messages_nodejs
[ 16%] Generating EusLisp code from kuka_arm/CalculateIK.srv
Scanning dependencies of target moveit_ros_planning_gencfg
[ 25%] Generating EusLisp manifest code for kuka_arm
[ 25%] Built target moveit_ros_planning_gencfg
Scanning dependencies of target graph_msgs_generate_messages_nodejs
[ 25%] Built target graph_msgs_generate_messages_nodejs
Scanning dependencies of target moveit_ros_manipulation_gencfg
[ 25%] Built target moveit_ros_manipulation_gencfg
Scanning dependencies of target kuka_arm_generate_messages_cpp
[ 33%] Generating C++ code from kuka_arm/CalculateIK.srv
Scanning dependencies of target kuka_arm_generate_messages_nodejs
[ 41%] Generating Javascript code from kuka_arm/CalculateIK.srv
[ 50%] Generating Python srv __init__.py for kuka_arm
[ 50%] Built target kuka_arm_generate_messages_nodejs
Scanning dependencies of target shape_msgs_generate_messages_nodejs
[ 50%] Built target shape_msgs_generate_messages_nodejs
Scanning dependencies of target gazebo_grasp_fix
[ 50%] Built target kuka_arm_generate_messages_py
Scanning dependencies of target kuka_arm_generate_messages_lisp
[ 58%] Generating Lisp code from kuka_arm/CalculateIK.srv
[ 58%] Built target kuka_arm_generate_messages_cpp
[ 58%] Built target kuka_arm_generate_messages_lisp
[ 75%] Building CXX object RoboND-Kinematics-Project/gazebo_grasp_plugin/CMakeFiles/gazebo_grasp_fix.dir/src/GazeboGraspFix.cpp.o
[ 75%] Building CXX object RoboND-Kinematics-Project/gazebo_grasp_plugin/CMakeFiles/gazebo_grasp_fix.dir/src/GazeboGraspGripper.cpp.o
[ 75%] Built target kuka_arm_generate_messages_eus
Scanning dependencies of target trajectory_sampler
[ 83%] Building CXX object RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/src/trajectory_sampler.cpp.o
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp: In constructor ‘TrajectorySampler::TrajectorySampler(ros::NodeHandle)’:
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:180:43: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in initialization
bool success = move_group.plan(my_plan);
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:224:15: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
success = move_group.execute(my_plan);
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:291:39: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in initialization
bool worked = move_group.move();
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:313:13: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
success = move_group.move();
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:339:13: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:351:13: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:375:15: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:452:39: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in initialization
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:497:13: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in assignment
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp: In member function ‘bool TrajectorySampler::OperateGripper(const bool&)’:
/home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/src/RoboND-Kinematics-Project/kuka_arm/src/trajectory_sampler.cpp:543:33: error: cannot convert ‘moveit::planning_interface::MoveItErrorCode’ to ‘bool’ in initialization
bool success = eef_group.move();
RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/build.make:62: recipe for target 'RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/src/trajectory_sampler.cpp.o' failed
make[2]: *** [RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/src/trajectory_sampler.cpp.o] Error 1
CMakeFiles/Makefile2:3178: recipe for target 'RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/all' failed
make[1]: *** [RoboND-Kinematics-Project/kuka_arm/CMakeFiles/trajectory_sampler.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 91%] Linking CXX shared library /home/abouseif/main/udacity/roboticsnd/robotics_term1/ROS/catkin_ws/devel/lib/libgazebo_grasp_fix.so
[ 91%] Built target gazebo_grasp_fix
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j4 -l4" failed
rosdep update
and thenrosdep install --from-paths . --ignore-src -y
from yourcatkin_ws/src
directory. $\endgroup$ – Petch Puttichai Dec 16 '17 at 2:42
