-1
If my state vector is just a representation of the error state of a quaternion represented as $[\delta \bf{q} ]$ which is a 3x1 vector and my external update is from an accelerometer, how would I compute the jacobian $\bf{H}$ matrix?
One implementation that I've found uses $$ \bf{H} = [R^w_b g]_\times $$
where $\times$ represents the skew symmetric matrix and $\textbf{g} = [0, 0, 9.80665]^T$, $\textbf{R}^w_g$ the rotation matrix obtained from the true state quaternion.
How does $z = Hx$ make sense in this formulation? Thank you!
    $\begingroup$ Welcome to Robotics, Nopestradamus. Can you link to any of the original papers you're referencing? A quaternion should be a four-valued item, so I'm a bit confused as to how your quaternion error state only has three. As @VivekShankar mentioned below, it would appear that your predicted acceleration observation, $z$, is the result of taking the direction you expect gravity to be pointing, $R_b^w g$, and modifying that by your best guess for how your rotations have changed $\delta q$. $\endgroup$ – Chuck Dec 27 '17 at 14:14
  • $\begingroup$ The result should be the "future measurement" of gravity, but again I can't reconcile a 4x1 quaternion with your 3x1 quaternion error state, and I'm not sure I know of a direct method for "applying" a quaternion increment to a rotation matrix. Again, if you could please link the paper(s) you're reading then we might be able to better help you. $\endgroup$ – Chuck Dec 27 '17 at 14:16
The way to relate Accel measurements to orientation is through Gravity. When there is no user motion, only force experienced by the accel is Gravity.
In your case, I think the interpretation must be: How does my measurement of Gravity match up to predicted Gravity?
