I am trying to run "px4 SITL simulation" using gazebo7 on my machine with "UBUNTU-14.04 LTS" using these commands:
mkdir -p ~/src
cd ~/src
git clone https://github.com/PX4/Firmware.git
cd Firmware
git submodule update --init --recursive
But as I enter the next command i.e :
make posix_sitl_default gazebo
It gives an error -->
CMake Error: The source directory "/home/arpit/src/Firmware/build/posix_sitl_default/-Wno-deprecated" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
/bin/sh: 1: cd: can't cd to /home/arpit/src/Firmware/build/posix_sitl_default
make: *** [posix_sitl_default] Error 2
Any Solutions?
  • 2
    $\begingroup$ There might be a problem in the Makefile. Particularly, the fact that the build directory and one of the C flags are concatenated together. I would suggest checking out a certain tag (1.6.5 seems to be the latest?) and build that. You might have taken the code at some buggy in-development state. $\endgroup$
    – Shahbaz
    Oct 26, 2017 at 15:06
  • $\begingroup$ I think you executing make command in the wrong directory, please go to build and execute make command, please let me know whether it works? $\endgroup$
    – Monika
    Dec 18, 2019 at 19:41
There's something wrong with the Makefile where this is breaking depending on your exact setup. As a quick fix I would hack out the -Wno-deprecated from the Makefile, and I'll look at fixing this.
I think there is a missing space in the makefile. the flag should be on a separate line from directories. That is as far as I can say since I don't have the file.
