I would like to connect my RP3 to the HKpilot. While most connections are pretty straightforward, I would like to know how ca I power the PI:
- It is stated in the above link that "The RPi can be powered by connecting the red V+ cable to the +5V pin", can the HK32 pilot deal with the power consumption of th RP?
- It is also stated that "The RPi can be powered ... from USB in", in this case, there is the grouding is shared? From where can I get a 5v output? Do I need to build a voltage regulator?
Thanks,
