I'm currently working with Kinect v2. I can do all sort of stuff on PC with it. What I want to do next is, to get the data I want on PC and control the Raspberry Pi with that data (for example, I will move the Pi with motors when I tilt my head to right). I have sorted out the motors and everything but I just don't know how to use that tracking data I have on PC to control the Pi.
I hope the question makes sense, i'm just extremely new to both Pi and Kinect.
Edit: Further clarification of what I'm trying to achieve.
I have a Raspberry Pi which is connect to 2 step-motors through a motor driver. With this setup, I can run a Python script and turn on or off the motors with that.
Now I also have a Kinect V2 connected to my PC.
What I want to achieve is, to issue the 'turn on - turn off' commands from the Kinect which is connected to my pc and not the Pi. I want to tell the pi from my computer, for example, when I turn my head left, turn on the motors connected to the Pi. I can issue the commands through the python script inside the Pi. Now I want to issue those commands from my PC which has the Kinect data and I want to do it through WiFi connection.
- Step1: Get the head movement data from Kinect on my PC.
- Step2: Send that data to Raspberry Pi, somehow(The step where I have the problem).
- Step3: Pi turns on motors according to that data.
I hope this clerifies the problem.
Thanks for the help!
