I have successfully controlled an analog 360 degree servo using a slide potentiometer, with the pot sending a 1000ms signal at one end of the pot and 2000 ms at the other. This gives me nice and smooth rotation speed control all along the pot axis.
I recently got hold of TowerPro MG90D servos, which would be ideal for the app I have in mind because of size and power, but I do not seem to find the right signal to send. If I run the same code, I get the servo turning 100% clockwise first, then in the middle a jittery very small step movement, then at some point full speed counterclockwise.
So my question is, what is the signal I should be sending to the digital servo?
This servo is indeed a 360° servo. Please see https://youtu.be/pyGhbPLZA04
Many thanks in advance!
  • $\begingroup$ At least some sources say this servo has "Normal Servo Travel: 90° (45° each way)". Not a "360 degree servo". BTW, most servos (that I have seen) only travel 180 degrees. $\endgroup$ – st2000 Oct 6 '17 at 13:03
  • $\begingroup$ You describe a system with a slide potentiometer, ie able to change a resistance, which generates a change in time period. Although to change the motor speed and direction of rotation you should vary the tension at its ends. Somehow your system description is not complete. $\endgroup$ – N. Staub Nov 7 '17 at 11:09
  • $\begingroup$ The thing is, it works fine with an analog 360 degree servo. All I need to hear is, how does one control a digital 360 degree servo. The potentiometer sends out a value of 0 to 1023, which I convert to a value between 1200 to 1800 respectively. This value is sent to the servo as the length of the control pulse. I would love to find out the way to send control pulses to a digital servo. $\endgroup$ – Heikki Hietala Nov 11 '17 at 7:29
