I have been working on a code where an A.R Drone 2.0 will detect color and put a red dot in the middle of the image. I am using streaming for the drone. The goal is for the drone to detect a white gutter and fly straight over it from one point to the other. Essentially following a line. I noticed when I changed the BGR to 0, 0, 255, I get the entire gutter to be distinguished but it detects white spots as well. Is there to isolate my detection just to see the gutter. Maybe using shapes, once the gutter is detected, put a bounding box. And my finally question is how do I tell my drone to follow the red dot or maybe drawing a line. I looked at python-AR drone libraries but don't know how to apply it.This is my code.
import numpy as np
import cv2
# open the camera
cap = cv2.VideoCapture('tcp://192.168.1.1:5555')
def nothing(x):
    pass
cv2.namedWindow('result')
# Starting with 100's to prevent error while masking
h,s,v = 100,100,100
# Creating track bar
cv2.createTrackbar('h', 'result',0,179,nothing)
cv2.createTrackbar('s', 'result',0,255,nothing)
cv2.createTrackbar('v', 'result',0,255,nothing)
while True:
    #read the image from the camera
    ret, frame = cap.read()
    #You will need this later
    frame = cv2.cvtColor(frame, 35)
    #converting to HSV
    hsv = cv2.cvtColor(frame,cv2.COLOR_BGR2HSV)
    # get info from track bar and appy to result
    h = cv2.getTrackbarPos('h','result')
    s = cv2.getTrackbarPos('s','result')
    v = cv2.getTrackbarPos('v','result')
    # Normal masking algorithm
    lower_blue = np.array([h,s,v])
    upper_blue = np.array([180,255,255])
    mask = cv2.inRange(hsv,lower_blue, upper_blue)
    result = cv2.bitwise_and(frame,frame,mask = mask)
    cv2.imshow('result',result)
    #find center
    cnts=cv2.findContours(mask.copy(), cv2.RETR_EXTERNAL,cv2.CHAIN_APPROX_SIMPLE)[-2]
    center=None
    if len(cnts)>0:
        c=max(cnts, key=cv2.contourArea)
        ((x,y),radius)=cv2.minEnclosingCircle(c)
        M=cv2.moments(c)
        center=(int(M["m10"] / M["m00"]), int(M["m01"] / M["m00"]))
        if radius>10:
            #cv2.circle(frame, (int(x),int(y)), int(radius), 2)
            cv2.circle(frame, center,5,(0,0,255),-1)
    # color detection limits
    lB = 5
    lG = 50
    lR = 50
    hB = 15
    hG = 255
    hR = 255
    lowerLimits = np.array([lB, lG, lR])
    upperLimits = np.array([hB, hG, hR])
    # Our operations on the frame come here
    thresholded = cv2.inRange(frame, lowerLimits, upperLimits)
    outimage = cv2.bitwise_and(frame, frame, mask = thresholded)
    cv2.imshow('original', frame)
    # Display the resulting frame
    cv2.imshow('processed',outimage)
    # Quit the program when Q is pressed
    if cv2.waitKey(1) & 0xFF == ord('q'):
         break
# When everything done, release the capture
print 'closing program'
cap.release()
cv2.destroyAllWindows()
