can anyone please tell me if the sensor output is 0 to +-10V, and i connnect the sensor to differential amplifier to get an output of 0 to 3.3V then what is the input voltage to differential amplifier from -10v to +10v or (0 to 10 v or -10 to 0v). if i use -10 to 10 volts then differential amplifier add both the input voltages and give +20V and with gain we can adjust it to 0 to 3.3, but if i use 0 to 10v or 0 to -10V then i get half voltage with the above set gain. Can anyone please explain. Thank you
A differential amplifier amplifies the difference between the signals. If you had a differential amplifier that scales a ±10v differential signal to a 0 to 3.3v signal, it would expect that the maximum input would be a 20v difference between the terminals. That's why you need to apply a 20v signal to the input to get the output you want.
If you have a sensor that outputs from -10v to +10v then you would need to apply 10v to one side of your differential amplifier so that 0v from your sensor corresponds to 1.65v out, -10v is 0v and 10v is 3.3v
| improve this answer | |
