I am looking for a rotational actuator with high torque and one whose rotation angle can be controlled using the arduino control signals The project is an e-brake for an e-bike.
Working mechanism The control input from sensor is fed to arduino and from arduino to an actuator . The actuator(to which the brake wire is connected)should rotate a predefined angle so that the brakes are engaged
Any suggestions on implementing this? Or any other alternative mechanisms for suggestion?
  • $\begingroup$ Welcome to Robotics Suhas, but I'm afraid that shopping questions really aren't a good fit for a stack exchange site. We prefer practical, answerable questions based on actual problems that you face. Take a look at How to Ask and tour for more information on how stack exchange works, and the Robotics question checklist for details of how to write a good question. $\endgroup$ – Mark Booth Sep 29 '17 at 8:47
  • $\begingroup$ Ok. If u could suggest just a practical mechanism for e braking system even that is fine ๐Ÿ˜‰ $\endgroup$ – Suhas Sep 29 '17 at 14:37
  • $\begingroup$ The problem is, there are many ways to solve any given design problem, so questions which ask for a list of approaches or a subjective recommendation on a method are off-topic. If you include details of what you want to achieve, what you tried, what you saw & what you expected to see, then we can help you solve that problem. Without those details though, it is difficult for us to give you anything other than the most generic answer. $\endgroup$ – Mark Booth Sep 29 '17 at 14:48
Typically arduino can not directly be plugged to an actuator without a motor control board in between. A motor control board is just a power stage allowing higher voltage and current than the ouptut one provided by the arduino. Typically those board are controlled with PWM signals that can be easily generated from arduino.
In order to get a better answer as for the actuator you should provide a estimated of the torque needed, the desired reaction time which can of breaking system you plan to use and where you plan to break (on the wheel outside? at the crank set?)
| improve this answer | |
  • $\begingroup$ The break would be on the wheel. $\endgroup$ – Suhas Sep 29 '17 at 14:26
  • $\begingroup$ The break would be on the wheel.And well can u please suggest me a mechanism for braking ( like for instance I could use a linear actuator that moves a certain amount of distance based on control signal from arduino but practically its not easy to use that for braking ) so if u could suggest me a type of actuator that could be used in a braking system it would be fine.The programming and driving part of it I can take care of that . $\endgroup$ – Suhas Sep 29 '17 at 14:35
  • $\begingroup$ On stack exchange, it is better to edit your question to clarify points raised in answers, rather than adding comments. Comments are for helping to improve questions and answers, and are distracting, so we try to keep them to a minimum. If all of the information needed to answer the question is contained within it, the comments can be tidied up (deleted). $\endgroup$ – Mark Booth Sep 29 '17 at 14:49
