I am trying to fuse a u-blox M8 with a MicroStrain IMU via a loosely coupled architecture.
I was wondering if there are any suggestions or insights based on the results that I am getting.
I based most of my code off of Paul Grove’s 2nd edition book. I did a six-point tumble test to calibrate my IMU to get the accelerometer fixed bias, the accelerometer scale factor and the accelerometer misalignment. I also got gyroscope fixed bias. I don’t have a rate table so I can’t get the gyroscope scale factor and misalignment yet.
The filter is not currently estimating any calibration information.
I ran a test of the code for about 6 hours and 40 minutes.
I have a couple of questions about the procedure.
  1. My main difficulty is that I am not sure what I should be expecting from the hardware/integration architecture that I am using. What would you expect after a test of 6 hours with a loosely coupled architecture?
  2. I am also having difficulty deciding on how to tune the filter. Are there any papers/procedures that you recommend for deciding what should go into Q and R Matrices? I tried propagating the IMU standalone to see how quickly it diverged from it’s initial position. I also took gps data to see how it diverged from it’s initial position. I am wondering If the tuning would be a function of my update interval, as well as how long it takes the two systems to diverge to a specified distance.
    For my R matrix, I am taking the uncertainty posted by the GPS. For my Q matrix, I am using the power spectral density. I do have some difficulty understanding the reasoning behind this.
  3. Finally, I am wondering how much you think that estimating calibration information in my filter would help with a long term solution.
int and gps x ned and y ned
int and gps ecef x and y
int and gps ned x
int and gps ned y
int and gps ned z
Please ignore the xlabel for the figures. It says time in seconds was about 28 days. But the test lasted for just 6 hrs and 40 minutes.
7
  • 2
    $\begingroup$ I haven't read your code thoroughly, but from the figures it looks like you haven't really solved drift (your x drifts about 1.5 meters per hour). Have you verified that the bias agrees with your test data? You might get more traction on this post by focusing your question - generally a list of questions is more difficult to digest and find an answer for. $\endgroup$
    – combo
    Sep 20, 2017 at 15:59
  • $\begingroup$ Hi @combo. How would I test that my bias agrees with my test data? Do you mean propagating the IMU state without biases and then seeing if the position divergence is consistent with the bias measurement? $\endgroup$
    – rielt12
    Sep 20, 2017 at 16:08
  • $\begingroup$ More like having the unit still and level, then compute the averages of the accelerometer xyz. You should be subtracting this bias from the raw readings before passing them as input to your kalman filter - after skimming your code it's not clear where you do this. By checking the bias I mean comparing the means you are subtracting with the observed mean over the long test duration. $\endgroup$
    – combo
    Sep 20, 2017 at 16:58
  • $\begingroup$ Why would averaging the outputs of the accelerometer be the bias? I used this method for Calibration: commons.erau.edu/cgi/… Or are we saying the same thing? $\endgroup$
    – rielt12
    Sep 20, 2017 at 17:13
  • $\begingroup$ The tumble test is a good method for calibration - and if the calibration is correct, then when you have the accelerometer stationary with $z$ aligned down, then after compensating for bias you should measure zero average acceleration in $x$ and $y$. Based on the figures you posted, this is not the case since introducing the imu data adds significant drift over long periods of time. $\endgroup$
    – combo
    Sep 20, 2017 at 17:29
Do you have a simulation? I would recommend that you simulate the data first to debug and tune your KF. The simulation should model the true IMU outputs (Grove has some details on that) and true position with error models. Start with truth to make sure the KF estimates zero errors, and then add errors one at a time (bias, SF, Misalignment, noise, etc.) to see if those can be estimated. Since it is a simulation you know truth, so you know how well it is working. Once it is debugged and tuned with the errors turned on, then try real data.
