I have a Roomba 871 and I am trying to communicate with it through the sci port. I am using RealmTerm for testing, I am trying it with the How to Program Roomba - RealTerm Terminal guide.
If I try it with a baud rate of 57600 the only thing I am able to is to get the Roomba to perform an spot cleaning. To get to that the only thing I have to do is to send it an value of 130-139, 230-239, 330-33... But I have to send it as ASCII not as Numbers, like mentioned in the description above.
If I try it with a baud rate of 115200 the only thing I am able to do is to switch it off. But then it is switched off until I lift the Roomba up. Pushing the Power button does noting in that case. To switch it off I send the numbers like in the description above: 140 0 1 62 32 but send as numbers!
So this is quite strange and I really don't know what to do, so please help.
The right baud rate is 115200. If you did not changed it.
You need to send decimalcodes:
128 to start the interface.
135 to start or stop cleaning.
Try 128 135 at first.
Please refer to iRobot® Create® 2 Open Interface (OI) Specification
Here you find HTerm with roomba commands: https://static.vvcc.de/roomba/hterm_roomba.zip. Maybe it helps you. Just drag and drop roomba.cfg to HTerm.exe. No installation needed.
  • $\begingroup$ I tried to send 128 135 with RealTerm. I've pressed the button send numbers, so it should be right or? But nothing happens.... $\endgroup$
    – Binkowski
    Aug 22, 2017 at 12:17
  • $\begingroup$ It looks like you may have accidentally created two accounts (Binkowski & ChristianBinkowski). Stack Exchange only allows an individual to actively use one account, so please follow the instructions at I accidentally created two accounts; how do I merge them? Note that moderators can't merge accounts for you, but may delete accounts they believe to be sock puppets. $\endgroup$
    – Chuck
    Aug 24, 2017 at 18:52
