If I use an industrial robot with its hardware controller, should I install linux hard real-time like xenomai to use this kind of hardware controller?
If not, when is the case to use xenomai?
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityIf I use an industrial robot with its hardware controller, should I install linux hard real-time like xenomai to use this kind of hardware controller?
In general, hard real-time OSes are used when there is a (usually periodic) task that is terminally critical, i.e. a process that needs to be run every few milliseconds, for example, and which, when queued, must be completed within a given time window to avoid a system failure. Note that "system failure" in this case doesn't have to mean that it will fry your CPU or break your robot, but instead that the resulting behaviour is considered a breach of the system's critical specifications, such as user safety or the like.
You may want to check out the criteria for different categories of real-time computing on Wikipedia
You should find it useful to read this https://www.researchgate.net/project/A-Preview-of-Introduction-to-Fundamental-Principles-of-Dynamic-Real-Time-Systems. "Hard" real-time is a special case of the general case of "real-time." You can easily find that there are as many ad hoc "definitions" of all real-time terms as there are sources for those "definitions." That is a major disruption to both commerce and R&D in the real-time field. Such a thing is unimaginable in any other engineering or science field.
hard RTOS is up to few microseconds to nanoseconds, soft RTOS is between miliseconds to microseconds.
It depends how fast you are getting data from the sensors and how fast you need the controller to react. Most cases ubuntu works fine and you can use ROS. In cases of hard RTOS I prefer micro kernels like QNX.
If really want to get the best out of your industrial robot just go for a micro-kernel like QNX, there are ways to install modified versions of ROS then you can work over built controllers by the community. There are lots of good things already developed that will spare a good time.
