I am working on a robotic application under R.O.S. groovy Galapagos. I would like to make a tutorial about how create a template app with catkin_create_qt_pkg. I'm unable to call the script catkin_create_qt_pkg from my catkin workspace. I found it at the root : _/opt/ros/groovy/qt_ros/qt_create/script_ But even if I try to execute it as sudoer I got an error.
ImportError: No module named qt_create
I'm unable to determine what I have to do to make it work.
Why?
  • $\begingroup$ What OS are you running? $\endgroup$
    – Ian
    Jun 5, 2013 at 23:32
You will get better help for this question by asking on http://answers.ros.org, which is a similar, but more specific forum.
Hi sorry for being so late.
My OS is Linux Ubuntu 13.04.
I already fix that issue. It was weird I just reuse an ROS exemple, readapt it exactly as I did when post that message, and everything worked ...
Thank you for your help
Jonny
