I am using a LSM303 sensor to compute a heading and I want to turn my robot to a heading.
I have the simple code here:
int mag;
mag = compass.heading((LSM303::vector){0,-1,0});; //read the angle of the robot
Serial.println(mag);
while (mag != angle){
//while it isn't the desired angle turn and continue to update the robot angle
trex.write(0xE9);
trex.write(90);
trex.write(90);
In a function called with a speed and angle (heading), the trex part tells the motor controller to turn on a point and the while loop should test for when the desired heading is reached. However, testing using a couple of instances of Serial.println(mag);
I have determined that once inside the while loop, mag never changes which just means the robot turns indefinitely.
I have no idea why this would happen. Perhaps someone here does?
Thanks.
by itself and then move the compass and run it again it performs correctly and the heading changes as expected. $\endgroup$ – mark mcmurray May 2 '13 at 21:43
