Using ArduPilot software (fixed wing, ArduPlane), I know that after I boot up I need to keep the system sit still while the gyros initialise.
When I have ground station in the field it's easy to know when it's safe to launch because the telemetry message tells me. But I don't always fly with a ground station. In these situations I currently just sit and wait for a while before arming, then again before launching.
Is there some reliable rule of thumb? information in the blinking of the arming switch or buzzing that I haven't worked out yet? This UAV has PX4 autopilot hardware (with both Px4FMU and PX4IOBoard), including with buzzer and illuminated arming switch. The LEDs on the board are obscured (but I could make light channels from them if required).
(Note: I'm asking this question here to test the theory that robotics stack exchange night be an appropriate forum for these sorts of questions, which has been suggested a couple of times in response to the Area51 drones proposal.)
    $\begingroup$ To answer the parenthetical meta question: We have several drone related tags and I can confirm that autonomous drones are considered on topic on robotics. As each of the wikis say: "The drone tag should only be used on questions about autonomous drones which don't fit into the auv, uav or ugv tags" as discussed on meta. $\endgroup$
    – Mark Booth
    Jun 4, 2013 at 16:52
  • $\begingroup$ Hmm, the open source autopilot communities I'm involved with share knowledge about systems across a spectrum of autonomy, from remotely piloted vehicles to full autonomy. Also, questions extend beyond the vehicle to ground segment components, safety and legal aspects, etc. Unless the robotics taxonomy can extend to these things, we probably do need our own stack exchange. $\endgroup$ Jun 4, 2013 at 22:34
  • $\begingroup$ Comments aren't the place for this sort of discussion, but feel free to come over to Robotics Chat or start an Area51 discussion. $\endgroup$
    – Mark Booth
    Jun 4, 2013 at 22:46
  • $\begingroup$ If others want to join in, see our chat and Area 51 discussion. $\endgroup$
    – Mark Booth
    Jun 5, 2013 at 9:05
This depends on a few things. First of all, are you using ArduPlane or ArduCopter, and what mode are you in? For ArduPlane, your answers are here, and for arducopter, here.
In both cases, the software has safeguards that will not let you arm or start the motor while it is initializing. In both cases, the LEDs indicate when it is ready to arm or fly. Of course, these behaviours are mostly configurable. For example, you can set the MANUAL_LEVEL parameter in ArduPlane to 1 if you want to skip the accelerometer calibration on each boot.
  • $\begingroup$ it's fixed-wing (question updated, thank you). $\endgroup$ Jun 13, 2013 at 2:44
  • $\begingroup$ FWIW I use my "workshop level" accelerometer calibration, I don't manual level in the field. But that page tells me the answer, "When you power on your board at the field, you should leave the plane motionless on the ground ... until the three colored LEDs stop flashing (about 30 seconds)." $\endgroup$ Jun 13, 2013 at 2:54
The LEDs on the board indicate the status of the Ardupilot. See the LEDs on the boards on the Arducopter wiki for more detail. Of interest to you are likely the A (red), B (yellow), and C (blue) LEDs. LED A is solid when the motors are armed and blinks otherwise. LED B flashes while the Ardupilot calibrates. Finally LED C indicates the status of the GPS module if there is one.
Edit: I just noticed you are using Arduplane in which case you want to reference the LEDs and their meanings page on the Arduplane wiki. The meanings are basically the same though it appears you do not have the option arm/disarm the motors.
  • $\begingroup$ Nice page but it applies to the older AVR hardware (APM1 and APM2 boards), not the new generation STM32 Hardware (PX4FMU/PX4IO, etc). With a bit of digging I couldn't find an equivalent page in the new wiki. I think the page @foobarbecue mentioned is the current documentation. $\endgroup$ Jun 13, 2013 at 6:46
  • $\begingroup$ I did not realize a new generation was released. Thanks for the info! $\endgroup$ Jun 14, 2013 at 5:01
