I recently have been working on a little project. Unfortunately, I've ran into a bit of a road block with controlling servos using serial commands. The servos do appear to move when i put in any character into serial, but only a little. When i type in say, 90 characters of random gibberish, both servos connected to my arduino move several degrees. Here's my code:
#include <Servo.h>
Servo ULF; // Upper left front servo
Servo LLF; // Lower left front servo
byte index = 0;
int commandnum=1;
int steps = 0; // position of LLF servo
int partnum = 0; // unused for now
String command = ""; // the command we're building
void setup()
  LLF.attach(0);
  ULF.attach(1);
  Serial.begin(9600);
void loop()
  while(Serial.available() > 0) { // while there are more than zero bytes to read
      char in = Serial.read();
      if(in=='!') {
             //! is escape character
       commandnum++;
       partnum = 0;
       Serial.println("New Command. Command #: "+commandnum);
        break;
      command+=in;
      if(in == ' ') {
        partnum++;
        //if we have a space, there's a new section to the command
      if(command == "LLF") {
        Serial.read(); //skip a space
        Serial.println("Lower Left Foot Selected.");
        int angle = Serial.parseInt(); // find the angle we want
        Serial.println("ANGLE: "+String(angle));
        for(int pos = 0; pos < angle; pos++) // for loop through positions to reach goal
           LLF.write(pos); // write servo position
           delay(15);
        for(int pos = angle; pos > 0; pos--) // for loop through positions to reach goal
           delay(15);
Any help would be much appreciated.
EDIT: Another note, nothing is printed in the serial monitor.
Also, these are micro towerpro rc servos.
  • $\begingroup$ Can you give us an example of the commands you are sending to your program? Also, can you confirm that this is an Arduino sketch that you have included? $\endgroup$ May 18, 2013 at 23:29
  • $\begingroup$ Yes, it is an arduino sketch, and one of the things i've tried was LLF 9. $\endgroup$
    – Dylan Katz
    May 18, 2013 at 23:31
  • $\begingroup$ Have you tried higher values such as LLF 180? $\endgroup$ May 19, 2013 at 0:35
  • $\begingroup$ Yes, I tried 90, same result. $\endgroup$
    – Dylan Katz
    May 19, 2013 at 1:38
3 Answers 3
I rewrote your program a bit. Not tested since I have no servos.
#include <Servo.h>
byte index = 0;
int commandnum=1;
char in;                // character to read
int angle;              // desired angle
void setup()
  LLF.attach(0);
  ULF.attach(1);
  Serial.begin(9600);
void loop()
    // define a protocol for commands, maybe like this:
    // [XXX<d>] where XXX is command and <d> is the angle,
    // the brackets [] indicates start and stop of a "packet" ( the command ).
    // Example: [LLF120], [LLF035], [LLF005]. I am here assuming a 3-digit
    // value for angle.
    // You also need to reset the variables that holds the command data
    // when the command has been executed so that they are ready for the next command.
    // and to use parseInt() you must ensure that the serial buffer has all the
    // digits that you sent.
  if(Serial.available() > 0) { // if there are more than zero bytes to read
      in = Serial.read();
      if(in == '[') // start of packet, now read command
        command = "";
        // get command, 3 chars
        while(command.length() < 3)
                command += Serial.read();
            delay(10);
        // get angle
        while(Serial.available() < 3)
            delay(10);
        // flush buffer, all info received
        Serial.flush();
           delay(15);
           delay(15);
According to the Arduino reference for Servo.attach( ), you should be using pins 9 and 10, not 0 and 1.
Note that in Arduino 0016 and earlier, the Servo library supports only servos on only two pins: 9 and 10.
Verify that you are setting the proper pin number in code. Specifically, look at these lines in your originally-posted code:
void setup()
  LLF.attach(0);
  ULF.attach(1);
5
    $\begingroup$ also, pins 0 and 1 are shared by the send and recv lines of the serial interface and could be causing issues. i try to avoid using pins 0 and 1 at all unless i have to. $\endgroup$
    – Octopus
    Jun 12, 2013 at 22:23
  • $\begingroup$ This would explain why typing gibberish has an effect on the servos. $\endgroup$
    – Ian
    Jun 13, 2013 at 14:43
  • $\begingroup$ I need to attach many servos though, would this be possible to do? $\endgroup$
    – Dylan Katz
    Jun 20, 2013 at 22:15
  • $\begingroup$ It depends on what specific Arduino board you have. The Servo library supports up to 12 motors on most Arduino boards and 48 on the Arduino Mega. Did you verify that you're using the right pins for your board? $\endgroup$
    – Ian
    Jun 21, 2013 at 20:13
  • $\begingroup$ I'm using the uno, how would i know which pins to use? $\endgroup$
    – Dylan Katz
    Jun 22, 2013 at 4:20
Does a simple serial sketch work? If yes, then try using this code: What this does is it takes two bytes simultaneously, the first indicating the pin number and the second the analog value, and then sets the pin mode. I am sure you can modify it for your own needs. This is the code I use for my robot. Hope this helps. (sorry, arduino indentation is weird)
int pin = -999;
int val = -999;
int count = 0;
void setup()
    Serial.begin(9600);
void loop()
void serialEvent()
    //As soon as a byte arrives
    while(Serial.available())
        //Read it
       int data = Serial.read();
       if (count == 0)
           pin = data;
       else if(count == 1)
           val = data;
       count = count + 1;
       if (count == 2)
          //Time for reset
          count = 0;
          //execute
          analogWrite(pin,val);
