11
I just got a kit and im not sure if its me or not but it appears one of the continuous servos might be broken. What happened first when I plugged it into the microcontroller, it made a humming sound when I sent it commands. The second continuous servo didnt work at all
I played around with different ports on the aurdino based board, and to no avail, just a hum. Then I removed the humming servo altogether and just placed the second servo alone. the second continuous servo started to move in whatever direction I asked it to.
I plugged the first one in, only the second moved.
then I tried spinning them by hand, the second has much resistance, while the first one has dramatically less resistance, maybe 60% easier to spin by hand.
Is this something I can fix? Has anyone experienced these problems before?
Thanks in advance, you guys are great!
  • $\begingroup$ Welcome to robotics Ess Kay. Are you talking about a hobby (RC) servo rather than an industrial servomotor? The answers for each will be very different. $\endgroup$
    – Mark Booth
    Commented May 18, 2013 at 0:38
  • $\begingroup$ Please retag this question with either servomotor or rcservo according to the new tag descriptions (See also this meta discussion). Thanks, $\endgroup$
    – Mark Booth
    Commented May 20, 2013 at 15:42
  • $\begingroup$ I had a question, I tried to control a servo with the arduino, to the servo I attached a stick and at the end of the stick a little weight. After runing my code my servo tried to move the stick, but maybe it had not enough torque to move it so after that I paused the code. Then I tried to control the servo again without weight and this time it didn´t moved. Is it broken? why? Is there a posible solution? Thanks, $\endgroup$
    – user9460
    Commented Apr 8, 2015 at 19:03
3 Answers 3
6
There is at least two modalities along which servos (continuous or otherwise) usually fail: gear problems and motor breakdown.
When the gear fails (broken tooth, hard point, etc.), the servo may get stuck, free moving or any combination. When the motor breaks (usually the brushes inside the DC motor are the culprit), the servo stops working altogether (as if it was unplugged) or overheats and burns. In your case, since it's humming and behaves differently when actuated by hand, I'd think your servo has gear problem. Its relatively easy to take a look at the gear box as it is the first apparent area when opening the servo and it can easily be re-assembled afterward (on the contrary, checking the motor's brushes usually means breaking the motor open), so I'd have a look to confirm the diagnostic.
    $\begingroup$ Great answer. I took the thing apart and saw the gears were jammed. Pulled them apart and put them back in place and it is working great now $\endgroup$
    – Shadoninja
    Commented Apr 14, 2020 at 23:13
11
How Servos Work
Based on these details of your question:
I just got a kit [...] continuous servos [...] plugged it into the microcontroller
Combined with your "Arduino" tag, I'm betting that you are working with hobby (RC) servos modified for continuous rotation. Standard servos work by receiving a pulsed signal with a 20ms period (50Hz). Regular hobby servos will rotate to a specific angle based on the duty cycle (ON time) of the pulsed control signal. This on time can range from 500us to 2500us, but usually only a range of 1000us to 2000us is used so as to not damage the servo. The "neutral pulse" of 1500us will put the servo in the center position.
This Wikipedia article about servo control has a great picture regarding the pulsed control:
Servo Pulses
There are a few different ways that the servo works, but the most common type I've seen in use by hobbyists is an analog servo. As the motor turns, an internal potentiometer is adjusted creating a feedback path for the internal circuitry. The servo will continue to rotate until the potentiometer is at the expected position for the given pulse width.
There are numerous different ways of modifying a standard hobby servo for continuous rotation, so I won't go into that, but essentially, this feedback path is tampered with such the servo never thinks it is in the correct position when it gets a non "neutral" pulse. A mechanical stop on the internal gears is also removed. Once this is done, sending a non neutral pulse will cause the servo to rotate completely, with the speed of rotation dependent upon the pulse width.
Your Issue
When a non-modified servo is given a pulse, it will quickly rotate to the desired position and hold it as long as a pulse is being sent. It should be very difficult to manually turn the servo at this time, and doing so will cause the internal motor to hum as it draws excessive current trying to correct itself during this overload situation. If the servo is disabled (receiving no pulse) it can be manually manipulated with ease.
A modified servo will exhibit similar behavior when under too much of a load - it will hum loudly and draw excessive current. While your servo may not be overloaded, it is obviously exhibiting similar symptoms and is most likely defective. When being driven, manually turning the actuator or stopping it from turning in its desired direction/speed is not a good idea, so keep that in mind for your other servos.
When the defective servo tries to rotate, it is drawing so much current that the second servo cannot operate. That is why it worked fine once the defective servo was removed.
Eventually if it's under too much of a load, such as if it's holding a position and you force it in a different direction, or if its trying to adjust to a position and something is blocking it, it will burn out. As in a little puff of smoke will come out. This also happens with servos which eventually reach their end of life. You can generally smell the servo to know if it's dead.
In you're case, it hasn't died, but may be malfunctioning. You generally can't repair servos. If you had new electronics, you could, but unless its a $100+ motor, its generally not worth it.
  • $\begingroup$ Welcome to robotics Jonathan. It is difficult to know whether your answer is correct until the original question is clarified. It looks to me like your answer is assuming that this is an rcservo question. Industrial servomotors would not be expected to burn out as long as they are not being pushed beyond their continuous operating current, and industrial servo control systems would normally back off to a safe force after a short period of time. $\endgroup$
    – Mark Booth
    Commented May 29, 2013 at 12:21
