I'm currently working on calibration of robot tool. I have found some simple methods to get the tool centre point. But I'm sure how to get the tool orientation wrt the robot's tip (the point where the tool is attached to the robot). The assumption here is that the tool-free robot is calibrated.
I'm looking for solution which doesn't use camera and expensive sensors.
EDIT: The robot is 6dof. The accuracy I'm looking at is approximately 0.1mm. The programming will be C language (How is this info related to the calibration method?).
Could someone guide in this aspect?
  • $\begingroup$ Need waaaaay more info. What is the tool attached to? How.many degrees of motion? How accurate does it need to be? What are you programming it with? There are way too many unknowns to help here $\endgroup$
    – user241585
    Jul 21 '17 at 20:53
  • $\begingroup$ Hi @user241585, I've updated the information in my question. Could you also tell me how the programming language affects the calibration method? $\endgroup$
    – vinjk
    Jul 22 '17 at 3:55
    $\begingroup$ The language doesnt but, it will help to possibly look for a library you can use to help you $\endgroup$
    – user241585
    Jul 22 '17 at 3:56
You can also use a touch sensor, that can be as simple as a conductive pad that completes a circuit when a tool touches it to determine initial position with the distance of the tool length accounted for. It won't work unless you want the tool to return home for recalibration periodically though.
Also look into teach position method
  • $\begingroup$ Thanks for the answer. I had read abt the teach position method. Looks very promising to me. But could you explain a bit abt this sentence $\endgroup$
    – vinjk
    Jul 24 '17 at 13:26
  • $\begingroup$ "It won't work unless you want the tool to return home for recalibration periodically though." Sorry posted the previous message before completing it. $\endgroup$
    – vinjk
    Jul 24 '17 at 13:26
One method that doesn't require any sensors or cameras, is to use a pointer 'tool', mark some known points and use geometry.
Attach a simple pointer tool (something with a nice point on one end, but that is aligned with the mounting plate but just offset by a known length).
Then, move the robot so that the pointer is touching 3 or 4 points on the workspace surface (for example) and record their Cartesian X,Y,Z position as reported by the robot controller and mark them on the surface (probably best if the pointer tool is sharp enough to make a small point indentation).
Then, mount your tool and jog the robot so that the end-effector reference point is positioned on each of the previously marked points and record the Cartesian X,Y,Z from the controller again.
Now, from the initial pointer, you can subtract the offset to know where the tool mounting plate is in 3D. Then, using some simple geometry (e.g. on paper), you can use angles of triangles and trigonometry to calculate the angles between the tool end and the tool plate to obtain a rotation angles about X & Y.
